GM shows the love. 290hp, 340ftlb upgrade for $650
Old Jan 13, 2009 | 09:36 PM
  #91
405HP_Z06's Avatar
Originally Posted by mynameiswazy
that part number does not return any results from GMPP
GMPP won't list that part number because it's not a available separately, only with the kit.
Old Jan 13, 2009 | 10:24 PM
  #92
T-Rodius's Avatar
I thought somewhere on this site I remember seeeing pics of the modification that needed to be done to the stage kit. I had mine installed and my turbo keeps cutting out....several times in the past few days. Took it to dealer today, said it was a leak in the seal of an o-ring. Tightened it my check engine light went off and I was on my way. But it happened again later in the day and the check engine light is back on, so looks like another trip to the dealer tomorrow.
Old Jan 14, 2009 | 10:43 AM
  #93
DMarotta's Avatar
Taken from https://www.chevyhhr.net/forums/show...2&postcount=60
• The install of the map sensor is easy. The orange/black wire for the map, They say it has a different color. That issue is easlily fixed by the elimination of wires.
• The next step is the intake air psi and temp sensor on the lower pipe.
• The pitures on the instructions that ship with the kit shows the install for a Pontiac Solstice and this is incorrect for the HHR.
• For revised documentation and installation instructions specific to the Chevrolet HHR, GM dealers can go to: http://service-gm-forum.com/techforu...howtopic=27213
• Use a razor blade and cut the back notch (boss) off the sensor. This will work best unless you want to spend a few extra minutes pulling the pipe out.
• The kit instructions say that all the "pin terminals" are correct for both however, this is not the case.
• Review GM doc# 1913913 for the Pontiac Solistice and GM doc# 1910765 for the HHR. When you compare the schmatics on both the HHR and the Solstice you will see differences in the connections.
• You will find that the map and intake psi sensor on the Solistice share the 5vref and grd. Additionally on the Solistice the grey wire is the 5vref and the tan is the grd. This is not so on the HHR and when connected per the shipped instructions in the kit, the HHR engine will not start. GM doc# 1910765 shows that the tan wire is the 5vref and the grey wire is the grd and when connected accordingly the car will start immediatly.
Old Jan 14, 2009 | 10:58 AM
  #94
turbotech's Avatar
Thank you DMarotta. I didn't have enought time to find my post. That is exactly the definition of the installation. I recommend the pipe removal (best done if you have a lift to get it up in the air).
Old Jan 14, 2009 | 03:17 PM
  #95
More_Torque_More_HP's Avatar
when installing use the instructions ingnor color
The instructions are correct with the pin# to Pin# HHR SS wire colors are different than the Solstice so ignor the colors. The HHR SS service manual is not correct in the connector end views for the MAP and TMAP connectors. Changes have been submitted. Best advice is to wire per the pin #'s in the instuctions.
Old Jan 14, 2009 | 06:35 PM
  #96
turbotech's Avatar
With all do respect. If you wire per pin #'s, your engine will not start. If you ignore the colors,then which wire do you splice to the white #1 #2 #3 #4 wires??
Old Jan 14, 2009 | 07:12 PM
  #97
MAP and TMAP rewire
This is correct - wire pin to pin per this picture:
Old Jan 16, 2009 | 07:16 AM
  #98
T-Rodius's Avatar
Still waiting to hear back from the dealer what's going on. Gave them all the info from this site concerning the stage kit install. Since it happened 1 time before the upgrade they need to determine what caused this Turbo cut out issue. In talking to the tech he was thinking it may be a wastgate problem? Hopefully find out later today and I'll be able to pick it up. Haven't had much of a chance to play with the upgrade since it was installed last Sat. Been back to the dealer twice since then.
Old Jan 16, 2009 | 08:16 AM
  #99
Over Boost
It could be an over boost code. With the kit it is still possible to set the over boost code especially if the waste gate mod is adjusted too much
Old Jan 16, 2009 | 12:41 PM
  #100
esmarkey's Avatar
Bill what is the maximum amount of boost before an over boost condition occurs?
