GM Turbo Upgrade - How to Check Lower TMAP Wiring
Old Dec 6, 2010 | 08:09 PM
87silver's Avatar
During oil changes, I always check the clearance of the lower TMAP wiring and connections in order to assure that there is enough room between the A/C piping and/or compressor so as not to cause abrasions. I changed my oil and filter over the weekend, so I decided to take some pics of it for the group's benefit. I provided some photos of where to jack up the car as well as where to look and what it looks like...
Use the bottom of the coolant reservior as a reference point to locate the sensor.
Clearance is highlighted in red.
Remember that this is a static view of the clearance. Insure that there is adequate clearance to allow for component movement and engine rock under high torque demand.
Old Dec 6, 2010 | 10:26 PM
got2boostit2's Avatar
Good information, well documented. Thanks!
Old Dec 7, 2010 | 10:38 AM
asanti's Avatar
I'm officially suggesting that ChevyMgr make this a sticky. It's simple and yet effective.
Later
Allex
Old Apr 29, 2011 | 08:45 AM
bad03xtreme's Avatar
I think mine may be hitting, I just looked and it's up against the bottom of the radiator.
Old Apr 29, 2011 | 09:27 AM
Doctor Who's Avatar
I have not done this yet, but was thinking would a motor mount like the TTR one help stop it from hitting since it helps eliminate some of the engine movement?
Old Apr 29, 2011 | 10:05 AM
asanti's Avatar
It definitely helps.
fonque
Aug 5, 2013 10:50 AM
SMH2010SSHHR
Jul 2, 2013 03:46 PM
ChevyGuySS
2.0L Performance Tech
11
Jul 12, 2011 08:53 AM
acpantera
North East
Apr 1, 2011 12:37 PM
jomack
Apr 22, 2010 05:38 PM
