Loss of power after Stage Upgrade
Old Jan 14, 2009 | 01:51 PM
bartSS's Avatar
I've been beating on my car since day one. And even more after the stage kit. My clutch is just fine like the day I bought it. Didn't GM out the strongest blitch they had in this car for a reason? For the people who have theirs slipping already what are your daily driving habits on this thing? I'm just wondering. I mean I will be getting a new clutch but not until next summer or when I get a bigger turbo but that's to hold the power. And don't get me wrong I'm not bashing anyone I'm just curious
Old Jan 14, 2009 | 01:55 PM
camaro98z28's Avatar
What is the wastegate mod?
Old Jan 14, 2009 | 03:01 PM
DrLoch's Avatar
Originally Posted by turbofreak
Exactly, I was running 25 psi with Westers race tune. Now I have a GM stage
tune. Also have HPT so I can change at will after Lyndon retunes the GM tune.
The boost hits alot slower on the GM tune. The Westers hits with a rush.
The GM tune hits softer on a purpose tohelp protect parts. Thus the low rpm
on aftermarket is stronger but both are strong above 3500 on up.
BUT and it is a BIG BUT, the GM tune does not cause the clutch to slip in
4th or 5th gear. The boost is less than race tune but when the aftermarket
was lowered to similar boost as GM, the clutch still slipped- again I feel due to
how hard the boost hits. I believe the aftermarket can be modded to have best of both worlds. Before with race tune, I just stayed away from WOT
at the 3200 rpm range unless I downshifted.
The GM tune has bands where they are limiting the torque until after ~4000 RPM, obviously for a reason. I don't point and stab anyways, I roll into it.
Where in MI? Who did your stage upgrade?
Old Jan 14, 2009 | 03:21 PM
More_Torque_More_HP's Avatar
Limiting torque
GM Tune is not limiting the torque above 3000 rpm
Old Jan 14, 2009 | 04:27 PM
DrLoch's Avatar
This is where I go that info from. That being the case it isn't correct then, or my interpretation of the information is incorrect.
Attached Thumbnails Loss of power after Stage Upgrade-torque-vs-rpm-vs-gear.jpg
Old Jan 14, 2009 | 05:33 PM
  #26
turbofreak's Avatar
Not bashed- never have problem with stage tune just like you, only with
aftermarket that hit harder in the 3200 rpm range.
tf
Old Jan 14, 2009 | 05:34 PM
  #27
turbofreak's Avatar
Near Ann Arbor, dealer was Bill Crispin in Saline
Old Jan 14, 2009 | 05:36 PM
  #28
either way no limitations above 3000 rpm
Old Jan 14, 2009 | 05:39 PM
  #29
DrLoch's Avatar
Thanks.
Old Jan 14, 2009 | 06:07 PM
  #30
Urban Legend's Avatar
to Camaro98z28 the waste gate mod is just simply adjusting the wastegate actuator rod. If you get under your HHR find the turbo and you will see a threaded rod on the exhaust side (attached to the wastegate) i believe the nut is a 13/32 (deep socket). Just loosen the outer one a tad, then the one closer to the wastegate will get threaded on more. I think they say to leave 4-5 threads visible. you dont want to tighten it on all the way. After that just thread that outermost one on until you can tighten it down against the lever and other nut. Viola your done! Its a HUGE pain to do cuz of lack of room but it will help you produce boost faster and a tad more. However if you dont have the kit it will "relearn" and drop the boost back down to stock levels, yet you still retain the quicker spool. hope this helps you!
