Magnaflow Exhaust
Old Jun 18, 2009 | 11:13 AM
DLVRNIT's Avatar
Originally Posted by xtremekirk
One minor problem is that since the system is so much larger then the stock one, I have a minor bump while going over rail-road tracks. I think that its hitting the drivers side spring mount. So I'm just going to heat up the one hanger and bend it so it has the proper clearance
Glad to hear you are enjoying your Magnaflow system! Our's is for the 2.4 motor so is a paltry 2.25" Dia. and while installing we had the same clearence problem! Two things you should consider when adjusting the hangers:
1) Pipe is already close to the gas tank on the otherside of the Spring perch ?
2) Our muffler seems to sit lower in the back (barely noticeable) so when adjusting the hanger(s) try to refrain from over adjusting as the muffler could sit at a larger rake or tilt !
Good Luck and Enjoy,
Old Jun 18, 2009 | 12:12 PM
1Panel2NV's Avatar
If you're worried about heat you could use something like this:
http://summitracing.com/parts/THE-11620/
That's what I used for my crossover pipe.
Old Jun 18, 2009 | 12:30 PM
DLVRNIT's Avatar
Hey Kendall,
Gonna order one this week! Just don't know how much of an issue the clearence is on the SS version since it is New with limited info.....
intofocuszx3
2.2L Performance Tech
20
Jun 18, 2010 03:34 PM
camaro98z28
Jul 11, 2009 04:20 PM
itsallu
Feb 13, 2009 01:43 PM
