Misfire and turbo issues: yet another thread
Old Aug 10, 2016 | 08:29 AM
  #51
Backfire!!? I hope you mean something else.
The only way that can happen is valve timing, right? And, if the engine actually turns backwards the chain will jump and valves will bend.
Have you done a compression and leakdown
Old Aug 10, 2016 | 08:38 AM
  #52
v-twins's Avatar
my bad.. misfire. Same misfire code. I do hear a loud pop though
Compression yes.. results are somewhere here, pretty even all 4 cylinders.
Leakdown nope, I have not
Old Aug 10, 2016 | 08:51 AM
  #53
Have you looked at the timing chain for proper alignment? Maybe a visual on #4 cams. Any unexplained coolant loss/gas in coolant (that would be reason for leakdown) a known issue is a head gasket leak/block porosity between 3 & 4.
Old Sep 13, 2016 | 09:23 AM
  #54
v-twins's Avatar
No, I have not looked at the timing.
could that really get screwed just like that?
As far as coolant, no lose as far as I can tell
Old Sep 13, 2016 | 09:34 AM
  #55
v-twins's Avatar
Anyway... I am getting ready to work on the car in the next 2 or 3 weekends. I also have to replace a fender, so that's more work added to it.
Work:
Replace IC piping, upper and lower because of a leak
Replace injectors seals
Pop valve cover and check
Parts:
Performance Autowerks IC piping
Injector seals kit
Valve cover gasket
Intake gasket
Throttle body/intake seal
Anything I may be missing?
Since I'm at it, I'll look at the valves and see if they need walnut blasting.
I'll move injector 4 to cylinder 3 to see, once everything is back together, IF the injector itself is the issue. Too late?
any tips and tricks? sealants to use with the gaskets?
If anybody is interested, I have and INJEN upper IC pipe for Cobalt, black, new. I wanted to use it, but wasn't aware in the air filter clearance.
Old Sep 13, 2016 | 10:26 AM
  #56
DrLoch's Avatar
Did you make the seal tools?
Old Sep 13, 2016 | 10:28 AM
  #57
v-twins's Avatar
YEP!!!
Done, all thanks to you!
Old Sep 13, 2016 | 12:10 PM
  #58
I am not aware of any gaskets on an HHR that need sealant; well, maybe the oil pan, but in that case the sealant is the gasket.
Old Sep 13, 2016 | 12:20 PM
  #59
DrLoch's Avatar
My guess is you may find an injector seal that is bad
Old Sep 13, 2016 | 11:06 PM
  #60
v-twins's Avatar
thanks
