Need advice on oil service
Old Nov 21, 2009 | 08:44 AM
tireman1554's Avatar
Originally Posted by Hib Halverson
I'm sorry but, as a universal "test" for an oil with a synthetic base stock, that is pure, unadulterated BS.
Always enjoy reading your comments!
Old Nov 21, 2009 | 08:55 AM
BYFLIP's Avatar
To ole hib
try it mr. Bs. Maybe you will see it works before you voice your scholar knowledge.
Old Nov 21, 2009 | 08:59 AM
mistermike's Avatar
I use Pennzoil Platinum mixed with 1 Qt of Rotella synthetic to pick up a little zinc that has been banned from SM grade oil. Mobil 1 is good oil, but PP is a group IV base stock and is returning better UOA's from people who like spending money on that sort of thing.
Old Nov 24, 2009 | 09:06 AM
Hib Halverson's Avatar
The "Zinc" issue is widely misundersood and surrounded by urban myth.
Zinc--or, more properly "zinc dialkyldithiophosphate" (ZDDP or ZDP)--has not been banned. In fact, it is still used in virtually all engine oils sold today. In API SL/SM oils it has been mandated less, with the specification for ZDP now 600-800 ppm. There are many other products--such as the aforementioned Shell Rotella--which have higher quantities. Specifically, Rotella-T runs about 1100PPM.
The "zinc" issue is irrelevant to the HHR, anyway, because it affects only OHV engines with flat tappet camshafts. The 2.0, 2.2 and 2.4 Ecotecs are all dual-overhead camshaft engines and DHOC valvetrains have far less load at the cam lobe/lifter interface than do OHV engines and, thus, require far less ZDP in the oil.
Both Mobil 1 and Pennzoil Platinum have Group IV base stock components. From a reliability/durability standpoint, there is little difference between the two when used in any HHR engine.
But, if the concern is an engine oil of ultimate performance, protection and quality, then oils with Group IV base stocks are not the preferred choice. You want an engine oil product with a Group V base stock (that means ester-based) such as what Red Line sells.
I use Red Line 10W30 in my HHR as well as in the engines of all my other vehicles.
Old Nov 24, 2009 | 09:14 AM
urbexHHR's Avatar
I saw an add on tv for Mobil 1 High Mileage...
Wonder if it's worth giving it a shot in my Lumina... But that has a small oil leak, so that's why I never used synthetic in it before....
Old Nov 24, 2009 | 12:21 PM
Well? BYFlip? Care to respond?
Old Nov 25, 2009 | 07:51 PM
BYFLIP's Avatar
Originally Posted by tireman1554
well? Byflip? Care to respond?
reply to what? The poor guy was just concerned if the dealer put mobile 1 in his car when he had the oil changed not a class in how many parts per million of zinc dialkyldithiophosphate is present oil.
Nice to know. Maybe i can use it to smokescreen answering a question. Or not.
This has turned into a redline oil advertisement. Wonder if the purple stuff will work on that?
pipilo
Sep 2, 2017 09:43 AM
mallomar
Oct 27, 2016 05:48 PM
dlmhhr
Dec 28, 2013 12:43 AM
Lake Runner
Dec 10, 2012 09:33 AM
