Opinions on GM Stage 1 kit for auto SS
Old Apr 11, 2009 | 12:13 PM
  #51
millerrdjr's Avatar
Tightened clamps
I tightened the intercooler piping clamps today.
Was able to use a 1/4" drive ratchet and an 11mm deep socket.
There is not a lot of room between the radiator and the intercooler (good for scraping the forearms).
I won't say the clamps were loose but I did tighten them about one to one and a half turns (didn't want to over do it).
Initial test drive produced boost ALL the time, not intermittent.
I will reserve final judgment after a few more days of driving.
Old Apr 11, 2009 | 12:47 PM
  #52
ChevyMgr's Avatar
Originally Posted by T-Rodius
Kit was installed at the dealer. is there a way I can check to see if they replaced the O-rings?
There is no way to not replace the O-rings, because without them the sensor just flops around in the hole and the vehicle wouldn't start. The new O-rings are much larger than the ones that come on the sensor. They are actually injector O-rings.
Old Apr 13, 2009 | 11:23 AM
  #53
More_Torque_More_HP's Avatar
O-rings
The sensors can be installed without the new o-ring. I witnessed a tech doing it last Wednesday. Once bolted in place you would not know. But the system would leak and loose boost.
Old Apr 13, 2009 | 12:27 PM
  #54
robotworkshop's Avatar
Can you suggest any dealers in the Detroit area that have done the installs and already know the right way to do it? I've talked to a couple in the area and neither really wanted to touch it....
Old Apr 13, 2009 | 03:31 PM
  #55
Dealer
Rinke Chevrolet in Warren.
Old Apr 13, 2009 | 03:47 PM
  #56
millerrdjr's Avatar
Intermittent is back
WAS ok until this morning, intermittent is back. I experimented a bit, while rolling along with no boost, I put it in neutral and revved the engine a bit. After waiting for it to return to idle, placed it back in "D" and the boost returned. Still seems like it could be a leak, or what?
Old Apr 14, 2009 | 01:42 PM
  #57
JeramieJJ's Avatar
Take it to a dealer that knows what their doing under the hood. Not all service departments are equal.
Old Apr 20, 2009 | 07:50 PM
  #58
Tim S.'s Avatar
Installed
I got my upgrade kit installed today they charged me 2.5 hours. The tech had trouble with the lower sensor and had to loosen my radiator to get to it. I also got Maintenance II done as well, overall bill $579.00. Tech said the vehicle was very responsive on the test drive and got 26psi out of boost.
On the way home I could not really get on it do to traffic but the places I played with the vehicle was very responsive and no lag time. I down shifted my auto tranny from 3rd to second about 45mph and goosed the go pedal and got some chirping of the tires. Overall so far I am impressed and happy. I now have a nice little pocket rocket.
Mowgli
46
Mar 18, 2010 02:26 PM
corvairman
2.0L Performance Tech
19
Feb 23, 2010 10:02 PM
gmdealerguy
Dec 20, 2009 09:51 PM
moonsign
Sep 25, 2009 12:54 PM
agentsmith23
12
Dec 16, 2008 06:48 PM
