PPC Tuners are ready for HHR!
Old May 24, 2008 | 10:48 AM
  #31
boosted5038's Avatar
are these tuners available for 5spd and auto?
Old May 24, 2008 | 12:31 PM
  #32
XXL's Avatar
XXL
ecoboost can provide a definitive answer, but I would imagine most of the tune work has been done on the engine, not the auto trans data... it's up to the driver to keep the engine spinning at the right RPM range for optimal performance (hence my comment in another thread as to why anyone would EVER buy a turbo motor with an auto trans and expect "high performance"... the auto just doesn't allow sufficient driver control of engine and turbo speed).
Old May 24, 2008 | 12:56 PM
  #33
EcoBoost's Avatar
Former Sponsor
Yes!
Old May 24, 2008 | 01:01 PM
  #34
Originally Posted by XXL
, but I would imagine most of the tune work has been done on the engine, not the auto trans data... ).
not real sure what your saying here. the graphs on his site say auto trans. there's no comparison between auto and 5spd stock to stock. the 5spd i drove would go right to 15-17lbs in any gear when put to the floor. the auto was real dissapointing to me with the way gm has it tuned. i'm real interested in knowing what 20-25lbs of boost would do for the 5spd wagon. i'm looking forward to ordering one up soon.
Old May 25, 2008 | 10:09 PM
  #35
XXL's Avatar
XXL
I'm saying...
ECM's generally have "maps" for engine performance characteristics, and "maps" for transmission behavior. In a manual transmission, most of the transmission "maps" go away. I would expect that, given the general flimsiness of the auto trans the HHR SS comes with, Hahn and PPC haven't spent much time tweaking transmission behavior (shift points, pump pressure, etc.), and instead have spent their R&D effort working on engine characteristics.
And re stick and auto, as I've said in a few other threads, a turbo vehicle with an auto transmission is a VERY poor performance combination. The whole value of a turbo is to keep it spooling at optimum... you simply cannot do this with an auto transmission where you have no real control over shift RPM and over the "between" shift engine RPM (with an auto, the engine RPM falls between shifts... as it's designed to, and so the turbo spins down, hampering the engine's ability to make power as it goes into the next gear. With a stick, the driver simply needs to blip the throttle between shifts to keep the turbo spinning optimally.
Old May 26, 2008 | 01:49 AM
  #36
norcalmike's Avatar
It just depends on what you want out of it. I am more than pleased with my Auto SS. It has all the power I need. I just wanted something that had decent power, handling and good gas mileage. If I had wanted the fastest car around I would have probably opted for the 5 speed.
Old May 26, 2008 | 11:25 AM
  #37
XXL's Avatar
XXL
Completely agreed. I'm speaking in terms of those interested in "performance enhancement" ... in the '90's (and I'm sure now as well) as Asian import cars starting down the performance route, a lot of people bought the "Honda DX" cars hoping to turn them into "Si's"... but were sadly disappointed that their base platform wasn't intended to do much more than it was designed from the factory. The "ricer" was born... because of their base platform, they were relegated to adding wings and stickers. While the SS auto isn't quite the same, it is inherently limited in the performance realm by the auto trans, whereas (to a point), the stick is not (that "to a point" being where the relatively wimpy Getrag transmission starts coming apart ).
My comments about auto trans turbo cars isn't intended to be a knock against them, but rather a bit of notice to owners that it is not a base platform from wihch you will likely appreciate significant gains by performance mods. Except in the corner case of highly modified track-only drag racing, the auto trans is, by design, a significant comprimise between performance and convenience. By all means, drive it and enjoy it like it is.
Old May 26, 2008 | 12:13 PM
  #38
tomw's Avatar
the auto trans is, by design, a significant compromise between performance and convenience. By all means, drive it and enjoy it like it is.
I Plan to!!!!!!!
Old May 26, 2008 | 08:44 PM
  #39
SdgrS's Avatar
Does anyone have numbers on a 5 speed? Making an automatic faster should be easy. It comes detuned from GM.
Old May 26, 2008 | 09:48 PM
  #40
c2vette's Avatar
The 5 speed is also way faster than stock. The increase in boost from stock 15 psi (6-10 in first) to 24 psi in all gears does just what you would expect. Motor feels and sounds smooth and healthy running at full boost (on 93 octane).
