Ram air
Old May 15, 2009 | 10:37 PM
foolmoon_design's Avatar
If you keep the air box, then seal it all in, that would make the ram sit off to the side a little bit, I think that would look pretty sweet, there is a guy around here that put a newer model mustang scoop on his Panel LT(functioning btw)
Last edited by foolmoon_design; May 15, 2009 at 10:41 PM. Reason: trying to add picture
Old May 15, 2009 | 10:40 PM
Little Red Wagon's Avatar
Here's a link to pictures of my Corvette with a cold air shaker hood scoop.If you look on page 13 of the pictures it shows how I put it together.
http://s35.photobucket.com/albums/d160/62f79/Corvette/
Old May 16, 2009 | 04:37 PM
mistermike's Avatar
Just so you know, a hood scoop is a cosmetic mod. Best case scenario is it's a decent cold air inlet. There's no such thing as "ram air" at velocities meaningfully below the speed of sound. Despite Detroit selling the concept for decades, this is a situation where the reality of the fluid dynamics is at odds with our intuitive grasp of it.
Old May 16, 2009 | 04:47 PM
Ratracer's Avatar
Hence, why a thin strip of flared plastic on the leading hood edge alleviates bugs from our winshield(and paint) or we never saw a newer working version of the cowl induction from a 70 Chevelle SS.
But one could dream............
Old May 16, 2009 | 07:30 PM
JB Toronto SS's Avatar
Could you make the argument that any gain from the better cold air inlet is offest by the reduced aerodynamics of the vehicle???
Old May 16, 2009 | 09:04 PM
cosmic1's Avatar
Ram Air
Forward facing scoops have a trade-off. They don't overcome their inherent drag until after a certain speed is reach (varies with car and scoop design). They do their best at high vehicle and engine speed when the engine can use every bit of air you can feed it. Rear facing scoops (i.e. cowl induction) only work well when certain parameters are met. They use the low pressure area at the base of the windshield and the vacuum created by air being pulled into the engine to create an increase in air flow into the fuel system. If the scoop isn't sealed to the fuel system inlet, it does nothing but look pretty.
Most scoops of the bolt on variety look tacky IMO. They look like something from Whitney or Warshawski (sp?).
Do what the Dodge Boys did back in the '60's, take out two of your headlights and use the openings to feed air to the engine (won't work on an HHR) but you could feed air from the lower grill opening. I know it don't look as neat, but if it works who cares.
Old May 16, 2009 | 11:10 PM
ecl's Avatar
ecl
I personally really like this SS
Old May 17, 2009 | 11:04 AM
THE BATMAN's Avatar
This is a scoop i found in a bargin bin at a giant auto, I had to cut out the holes, and then i made the custom grills, i think it fits the hhr's body style pretty good.
Old May 17, 2009 | 03:41 PM
JeramieJJ's Avatar
I converted my stingray to use the earlier years L88 cold air induction.
Old May 17, 2009 | 03:49 PM
IgottaWoody's Avatar
Functionality...I had a '73 comet w/302 that I had installed a early style mopar hood scoop(aftermarket) Inside was a moroso velocity stack with a filter mounted on top.The hole in the hood was no more then 1/2 in larger then the filter dia.,the entire filter protruded above the hood with the base at hood level opening.How well did it work? I had to watch weather as if the humidity was high and the weather a bit cool below 50f) I had to close off the opening because the air would ice the throttle base and lock the throttle and try to close the choke.Yes the exhaust xover was working.It was very efficient..though it was not planned to be..was just meant to be "pretty".
Having several scooped vehicles over the years, this was the only one that did this.
