Stage 1 Installed
Old Sep 22, 2011 | 12:34 AM
XtremeSS's Avatar
Testing for boost leak tomorrow I will keep all informed.
Old Sep 22, 2011 | 08:22 PM
Vcode455's Avatar
I'm in SE WI also and I can usually get 21-22psi on mine. I get the most consistent results in competition mode though. It seems to vary more in default mode. Have you tried the comp mode?
Old Sep 22, 2011 | 08:47 PM
XtremeSS's Avatar
Ya I tried em all..TC off, comp mode, and ESC off. Nothing above 18 psi. I've only seen 18 psi once since I started watching the gauge. And I still can't break the damn tires loose. Something ain't right. In the process of pressure testing right now.
Old Sep 22, 2011 | 08:55 PM
Did you say you can't break the mxm4's loose ???? When I picked mine up from stg1 install I could not get them to stop spinning, headed right to Discount Tire and traded them in. Your car has to be sick.
Old Sep 22, 2011 | 10:22 PM
XtremeSS's Avatar
Well....after trying to test pressure I found out ONE thing. The oil cap on the valve cover can only withstand about 15 psi until it starts to vent air. I don't think the oil cap is the problem cuz there isn't that much pressure in the valve area when the vehicle is running...right?
Littlemanhhr
2.0L Performance Tech
Oct 1, 2010 02:50 AM
andyb
18
Apr 27, 2010 09:57 AM
mountainman
Aug 5, 2009 01:50 PM
Cokeybill
10
Jan 18, 2009 09:14 AM
bartSS
156
Jan 3, 2009 09:03 AM
