What will I make on the dyno?
Old Jul 28, 2011 | 03:36 PM
bad03xtreme's Avatar
Originally Posted by foolmoon_design
This finally comes up. Most of the DP's have an angled O2 bung, which is the defouler. I have seen a couple of Cobalt DP's that don't have the angled bung, and then require to tune it out or add a defouler.
Yea the one I was going to get on a group buy didn't have the angled bung.
Old Jul 28, 2011 | 04:30 PM
RobSSTurbo's Avatar
The SS is strap down and ready to go I'll update with the base line.
Old Jul 28, 2011 | 05:06 PM
mightymouse's Avatar
awaiting your numbers sir!!!
Old Jul 29, 2011 | 05:17 AM
rallycobalt06's Avatar
ruh roh....... no results yet? someone has a sad? the suspense is killing me!!!!
Old Jul 29, 2011 | 07:13 AM
RobSSTurbo's Avatar
Results: 280tq 264hp
Dyno: mustang dyno
I'll explain later
Old Jul 29, 2011 | 07:42 AM
  #26
womp womp womp.........
are you still on the GM Stage 1 tune?
Old Jul 29, 2011 | 07:56 AM
  #27
bartSS's Avatar
with your mods meaning GMTU and boltons i did 286WHP 297TQ....
Its prolly those TTR mounts
Old Jul 29, 2011 | 08:09 AM
  #28
RobSSTurbo's Avatar
Numbers were ok, don't forget the temp last night was 93 in the shop and heat soak was bad my temps were 130 or higher which didnt help. I also run out time on the dyno so I have to do get another dyno day. Hptuners is also limited on the hhr since there not the same computer as the cobalts. I also one of my couplings pop off on a run when I hit 26 lbs stupid clamps. It was a long day but I'll redyno and get some solid numbers before the heat soak.
Old Jul 29, 2011 | 08:21 AM
  #29
get some t-bolts clamps while you're at it.
sorry but that's wrong about HPTuners being limited on the HHR, it is the same as the Cobalts. HPT isn't limited on my HHR.
Old Jul 29, 2011 | 08:24 AM
  #30
bartSS's Avatar
Not limited on mine either... Excueses excueses
