What will I make on the dyno?
Old Jul 29, 2011 | 08:59 AM
  #41
mightymouse's Avatar
something wrong. i was putting 261 on the bsr tune only in a hot garage. you should be 290-300 with your mods. also how much boost? if you are running 20psi on the hpt,then 300 is probably goingto be the max you see...maybe 310.
  #42
Careful there Asanti make sure you order the correct color granite for that sweet little old lady.
Old Jul 29, 2011 | 09:56 AM
  #43
bartSS's Avatar
Im running a 26psi tune and the thing runs strong as hell
Old Jul 29, 2011 | 10:44 AM
  #44
RobSSTurbo's Avatar
When I get home I'll check to see if I have the updated software.
Old Jul 29, 2011 | 03:36 PM
  #45
ATLsilverSS's Avatar
You want the beta version 2.23 I believe. That version has the fan adjustments you were looking for
Old Jul 30, 2011 | 04:18 PM
  #46
RobSSTurbo's Avatar
my hptuners was out of date i am uploading the 2.23 now explains the perimeters that were not showing up. ill done some logs and start working at it.
Old Jul 30, 2011 | 05:46 PM
  #47
you may have to have bill send the correct version to your hpt page. for some reason i couldn't download it right off the website and get it to work.
good luck bro
Old Jul 31, 2011 | 12:07 PM
  #48
RobSSTurbo's Avatar
It work for me and soon ill have another dyno setup to try again. How much boost can I push on the stock motor safely?
Old Jul 31, 2011 | 05:01 PM
  #49
Byt has done 30psi with no problems. A lot say 23 is the magic number but I think that is all bs. The highr the boost the more tq you will typically make so keep that in mind if you are on a stock clutch. Bart is at 26 me 25...it all depends on the tune. Make sure you don't get any kr and you should be good either way
Old Jul 31, 2011 | 08:52 PM
  #50
25psi here too where we are is probably the most efficient. you could go higher but you might start to lose in some areas. you have to upgrade the clutch to run higher boost or kiss your clutch good bye.
