Won't boost over 13PSI with stage
Old Mar 21, 2010 | 12:10 AM
  #71
IgottaWoody's Avatar
No change to tune.....it will boost(controlled boost-not like basic turbo systems that will go full boogy all the time) according to many variables, so boost can vary on back to back runs if conditions change.
Old Mar 21, 2010 | 05:21 PM
  #72
hyperv6's Avatar
Originally Posted by jmacallister
Here's the cell phone picture taken by my guy before attacking the abrasion point just left of the crappy electrician's tape job on the harness. Oops make that just to the right to the the four white wires that the upgraded MAP comes with. Rubbed through the tape - game over. If I can snake a lens down there again, I'll send a picture of what it should look like.
That is what mine looked like. We per GMPD shimmed the IC forward.
Many people do not realize the tube pulls up and back into the AC when the engine torques back under acceleration.
just a minor adj and all is fine now.
Old Mar 26, 2010 | 01:31 PM
  #73
Andy2.0's Avatar
Okay so since the 2.0 has a "smart turbo" for lack of any better term, it can boost more or less and it just depends on what the enviorment outside is?
Old Mar 26, 2010 | 11:50 PM
  #74
Enviroment..fuel capabilities( read that when it starts knocking the modules will kill timing and boost to save the motor )engine load.. what gear you are in... wheel spin......whether or not your wearing a red shirt that day..and how heavy your lunch was................
Old Mar 27, 2010 | 07:55 AM
  #75
hyperv6's Avatar
Yep this engine is smarter than most of us here.
Old Mar 27, 2010 | 10:34 AM
  #76
asanti's Avatar
^^ TRUTH!
Old Mar 27, 2010 | 07:56 PM
  #77
Andy2.0's Avatar
Alright, I was worried I was missing out on something. Thank you all.
Old Mar 29, 2010 | 09:25 AM
  #78
More_Torque_More_HP's Avatar
Stage Kit AC wire rub
The wire rub needs to be handled in two ways. 1. more clearance can created by Loosing the Intercooler to Throttle body tube at the intercooler and pushing the hose on as far as possible. One HHR even added washers under the intercooler mounting bracket to gain more clearance. 2. provide a friendly rub surface on the wiring harness. Use the corrigated plastic wire covering to protect the wires from rub through.
A rubbing wire in this area can cause a loss of boost without setting a code.
Old Mar 29, 2010 | 12:52 PM
  #79
jmacallister's Avatar
Thanks! My guy ended up doing both. Fingers crossed.
Old Apr 3, 2010 | 12:41 AM
  #80
Yup....wiring issue it is,,,, finally got under the car today and while it wasn't as obvious as I thought it would be, you can see where it was making contact( bad engineering to place it there when you have room nearby)...so as a temp fix until I can get it in I tied back the IC tube with a tye wrap to the radiator frame..and so far so good, no more turbo drop..so if your having this issue try the tie back for trouble shooting...
