2.2 motor question
Old Apr 12, 2017 | 09:17 PM
hurst2001's Avatar
Originally Posted by hurst2001
Well I had the timing chain done at 170000 with a new water pump .. now at 240000 getting no circulation out of it which tends to over heat which I was told by a mechanic I trust so I guess it time for the grave .. it was a gmb pump which I can't see degrade like that in 70000 miles .. oh well the car serve me good for ten years ..
Ok guys my mechanic pressure tested the radiator which was good had to replace the upper hose were you fill small leak new stat ac delco .. ok still no movement. As far as radiator fluid .. the car starts runs fine .. just the temp creeps up on it .. like I said I had the chain replaced with a new pump had use cloyed timing kit came with about everything ,so my question is the timing chain runs the water pump correct ? Ok what does the balance chain run the oil pump ? If any chain snapped the motor would not run correct ?
Old Apr 12, 2017 | 09:23 PM
The water pump is driven by the balance shaft chain. If that chain broke, it would run, but I think you would know it was broke. Here's a thread about a balance chain problem, and a way to check the chain https://www.chevyhhr.net/forums/ss-s...e5/#post797120
Old Apr 12, 2017 | 10:25 PM
hurst2001's Avatar
so if was broke you hear it .. just a little worried but like I said the car engine runs fine just the creeps up to a point to get hot ..
Old Apr 13, 2017 | 01:58 PM
hurst2001's Avatar
Anybody ever have the balance chain broke ? What would be the symptoms? My motor runs no bad shaking at all just curios..
Old Apr 13, 2017 | 03:28 PM
Watching the flow under the pressure cap can be misleading, checking the temp of the radiator outflow would tell you more. The impeller can break or come off the shaft. If the chain broke you would know it, it would vibrate like a 4 cylinder engine.
The pump "sucks" the coolant out of the radiator, no cap no flow.
Old Apr 13, 2017 | 06:18 PM
hurst2001's Avatar
thanks don for the input I'm have a radiator shop to put the new pump in .. they done it before because that's first thing I asked .. beside that comes with one year warranty so if anything happens it Thur baby ..
Old Apr 14, 2017 | 09:32 PM
cweagle7712's Avatar
Ive got at 2.2L in mine. Runs strong. Its an ecotec
Old Apr 15, 2017 | 04:34 PM
hurst2001's Avatar
Well the shop called and said chain was loose and one of sprocket was broke part of the teeth that's why no cicurlation going to replace chain sprocket inspect the oil pump and all replace balance chain tensioner major work .. get it fix and trade it in this sucks but hopefully make a little money or break even ...
Old Apr 16, 2017 | 06:41 AM
papa_jo's Avatar
that was some interesting reading! Thanks FireManGeorge
skyeglen
Apr 24, 2023 05:09 PM
hurst2001
Maintenance and Upkeep
Feb 8, 2020 02:32 PM
Kubee's
Apr 10, 2017 06:29 PM
captain howdy
Dec 7, 2005 12:38 PM
