2007 2.2 motor question
Old Apr 1, 2017 | 01:15 PM
hurst2001's Avatar
Got a 2.2 with 240000 miles my question is it using a quart of oil every 1000 miles so I was thinking of going with a supplement like restore product .. since I know the piston seals seen better days it would help the motor .. just trying to reach the 300000 mile mark .. any other tips on what to do? This car has serve me well as far as the motor and trans ...
Old Apr 1, 2017 | 01:22 PM
I thought mine was guzzling oil! Not so, it was sucking it out the hose from the valve cover to the elbow in the air cleaner hose to the throttle body!
https://www.chevyhhr.net/forums/2-2l...ormance-58332/
So far no further need to add oil every 300 miles!
Old Apr 1, 2017 | 01:35 PM
I would avoid "miracle" additives. Maybe change to dino oil or a different brand. GM claims 1 qt/1000 miles is OK.
Old Apr 14, 2017 | 01:57 PM
hurst2001's Avatar
Well a little up date when I put that restore product in my oil change fresh a week ago and know my oil light came on and then restarted it came on then the light goes off and stays off ... so I'm like wtf is it possiable that this stuff messing with the sensor ? I know it hard to tell over the internet just any help at all
Old Feb 6, 2020 | 04:28 PM
planetrj's Avatar
That is pretty wild... Possibly your additive might have cleaned off the sensors enough to make it begin sensing it correctly?
I also had a revelation. Of course, I don't know the past history of the type of driving on this car, except for the oil change, tune up, safety/service records on Carfax. But after I sprayed Gumout Choke Cleaner the air intake, PCV and each spark plug, the idle was very smooth, and the accellaration was impressively clean sounding, compared to before I did it.
Old Feb 6, 2020 | 06:45 PM
That is for older carburetor cars, could damage the sensors and throttle body. Next time use throttle body cleaner
Old Feb 7, 2020 | 02:49 PM
planetrj's Avatar
Do you have a suggested Throttle Body Cleaner, and do you know if that product will clean the intake and spark plugs like Gumout will? I've found Chemtool and Gumout work amazingly, and it was even recommened by a master mechanic I know who works exclusively on GM light duty and utility trucks contracted for the state. Thanks for any advice.
Old Feb 7, 2020 | 03:26 PM
These are a great kit and sensor safe
Also great for the SS DI intake valves
Old Feb 8, 2020 | 02:32 PM
planetrj's Avatar
EXCELLENT! My local O'Reilly's and Walmart carry this! Greatly Appreciated!
blacky
Maintenance and Upkeep
Aug 15, 2017 01:25 AM
seattlekev
Apr 24, 2016 02:59 PM
Highwang
22
Nov 9, 2012 06:10 PM
Lone Ranger
May 25, 2008 04:33 PM
muzik4life
Apr 6, 2007 07:15 AM
