2.2L Atuomatic Transmission Swap
Old Nov 8, 2020 | 07:07 AM
The transmission needs to be dropped down to access the side cover, not a job for a novice wrench.
Old Nov 8, 2020 | 01:39 PM
Fire_Wessle's Avatar
I figured that much. The thing with the shifting problem is that it only happens from first to second. The solenoid that controls that shift also controls the second to third shift and the car donest have any issues shifting from second to third in a similar rpm range. Could this be a sign another more serious issue? If theres not enough info to give a good answer, are there any tests I can do myself to find out more useful info for you guys?
Old Nov 8, 2020 | 06:04 PM
The 1-2 is one solenoid and the the 3/4 solenoid is the same part number but a different solenoid
Old Nov 8, 2020 | 08:06 PM
Ah ok I didnt have the diagram to look at while I was at work. I work at Advanced Auto and just searched the for the part and that's the Info I got. I defiently appreciate the all the help I've recieved with this. I'm going to ask a few mechanics I know about how much they would charge and take it from there, thanks guys!
Old Nov 9, 2020 | 07:22 AM
While you or they are in there, change all the solenoids , kits are available
https://www.ebay.ca/itm/302500593784
this looks tedious and painful
skyline26
Dec 27, 2025 06:10 PM
JoeyFeduka
2.0L Performance Tech
13
Nov 5, 2009 07:50 AM
bobby dazzlers
Apr 30, 2008 03:30 PM
upOnGamE
2.4L Performance Tech
Oct 13, 2006 09:10 AM
bisho1p
Jun 7, 2006 06:32 AM
