2006 hhr
Old May 20, 2020 | 05:36 PM
JGZA711's Avatar
2006 hhr
Recently, I had a motor replacement done due to a cracked block. Its been about 3 months now since I've had this done and I notice that every time I apply the brakes at a stop and upon releasing the brakes, my HHR will shut off. It doesn't do it all of the time, but it does happen often.
Old May 20, 2020 | 06:38 PM
Welcome to the site, after 3 months, I doubt the shop will fix this for free, sounds like a loose ground wire or the fuse box halves of the underhood fuse box are loose. Take the lid off and press down on all the fuses and relays, might cure your problem. If not come back and let us know.
Old May 20, 2020 | 08:03 PM
From the description, it may be a vacuum leak. I would check the brake booster and the vacuum line going to it.
Old May 21, 2020 | 07:05 AM
The intake manifold could be cracked where the vacuum hose connects
Old May 21, 2020 | 10:58 AM
Wouldn't a vaccum leak cause the engine to stall upon applying the brakes? OP says it stalls upon releasing the brakes.
Old May 21, 2020 | 11:47 AM
Depends. On applying the brakes it uses the vacuum that is already stored in the booster reservoir. When releasing the brakes, it allows the vacuum to pull again and replenish the reservoir ?
Just guessing on this problem. Thought it would be a place to check since the only connection between the engine and brakes is the vacuum supply.
Old May 21, 2020 | 03:10 PM
Hmmm, makes sense.
Insulin_addict
May 1, 2020 06:51 PM
Nancy Nadeanna Kromer
Jan 7, 2020 10:31 PM
gcsd3742
Apr 17, 2010 05:01 PM
john_a_basilio
Nov 22, 2006 04:03 PM
