Advice on timing
Old Jun 12, 2019 | 09:47 AM
Christopher hicks's Avatar
Advice on timing
Ok so im sure it's been asked and alot of my questions have been answered by searching but I was wondering if any one could tell me if any special tools are gonna be needed I'm sure a harmonic balancer puller but other than that. I'm a pretty good mechanic and have most tools and access to most others. Thanks btw it's a 2008 hhr panel with the 2.2
Old Jun 12, 2019 | 10:18 AM
Hmm. Maybe you should add what kind of work, repair or maintenance you're doing.
All I see is "timing" in the subject.
Old Jun 12, 2019 | 10:28 AM
I'll be replacing the chains,tensioners, and guides on both timing side and balance shafts as well as changing the water pump while I'm in there sorry for leaving that out
Old Jun 12, 2019 | 10:32 AM
Harmonic balancer comes right off, no puller needed, maybe a love tap or 2. You will need a way to hold it while getting the bolt on/off. The spec for that bolt is 74 lb.ft. PLUS 125 degrees.
DONOT remove the balance shaft sprockets. If you must change them get new balance shafts.
Old Jun 12, 2019 | 07:05 PM
You can change the sprockets on the balance shafts with out removing the shafts.
https://www.chevyhhr.net/forums/how-...in-kits-60394/
Old Jun 12, 2019 | 07:41 PM
I guess we should throw the service manual away.
Old Jun 12, 2019 | 08:39 PM
Isn't that referring to using the sprocket as a "handle" to facilitate removal of the shaft?
Old Jun 12, 2019 | 09:34 PM
The only other reference to the sprockets I can find is the torque specs; 71 LB.FT. plus 30 degrees. So take it whatever way you read it.
Old Jun 12, 2019 | 09:38 PM
To remove the balance shaft sprockets, you remove the retainer tab and use a drift to hold the sprocket from turning to remove the sprocket, do one at a time. And those are the correct torque values.
SwissHHR
Feb 6, 2018 07:44 AM
Banana hands
Apr 17, 2014 04:49 PM
wagoneer
Apr 9, 2009 11:44 PM
sp52075
2.4L Performance Tech
15
Jan 6, 2009 02:34 PM
07LTGuy
Aug 6, 2008 03:39 PM
