HHR Rotors
My 2006 HHR had brake pulse (front to back) and steering wheel shimmy at all brakng speeds at 20877 miles due to warped front rotors. They were resurfaced - as GM policy prevents dealiers from replacing rotors that have enough depth to resurface. If the dealer replaces "good" rotors under warranty, GM bills the dealer for the parts! Guess what, I now have 41,000 miles - and need new rotors.... because there is not enough metal to resurface again. But, I am out of warranty - and even under my "covers it all" extended warranty - wear items are excluded and brakes are wear items. In contrast, I have a 1993 ford escort wagon with the ORIGINAL rotors/drums - so it's NOT my driving. HHR brakes stink.
Just before first rotor resurface, the left front wheel hub assembly failed causing an ABS failure. This was replaced under warranty. Just before the second rotor problem, the right front wheel hub assembly failed causing an ABS failure and resulting in a single-car accident with side of road (almost 9k in damages). This time GM said it was operator error - so no warranty coverage.
NOTE TO SELF - buy a toyota hybrid next time.
He said his steering wheel was vibrating, and it is starting to again. I understand replacing brakes is a highly variable item, but my point was the steering wheel vibration should not be happening, there is some other issue that needs to be addressed by the dealership. I have never owned a vehicle that had a vibrating steering wheel due to worn out brakes, let alone at 13k and 18k miles. That is warranty stuff.
Warranty issue: brakes and rotors are wear items typically not covered by warranties. BUT - my first rotor resurface at 20877 mile was covered under warranty. At 41000 miles I need new rotors as there is not enough metal to resurface again. But, now I am out of warranty and GM will not touch it. However, EVERY mechanic I speak to GM/Toyota/Ford/Local folks/backyard tinkerers/street modifiers say, in essence "never resurface, always replace" and "rotors needing service on a new car should be covered under warranty and the rotors should have been REPLACED on the first failure NOT resurfaced."
By law they HAVE to. It is a documented recurring problem that originated during the warranty period and was never fully addressed. You should CALMLY speak with your service manager about it. If he doesn't give satisfaction, approach the dealership owner with the problem. If he fails to resolve it - (*and remember - the KEY to getting this resolved is maintaining your cool!), ask him to put you in touch with the GM district rep for your area. There have been many reports of HHR rotor problems in online forums - so GM knows the problem exists.
On the other hand, I replaced my rotors with nickel plated diamond slotted rotors at 4500 miles. Had no problems whatsoever with the stockers, just wanted better braking and "the look." If you need a set of stock rotors, I've got a set I'll sell you (a lot cheaper than buying dealer parts!). Mine are already broken in and trouble-free. Unfortunately, you will probably have to pay quite a bit for shipping, as they are very heavy.
Best of luck with it!
Oh, and if the rotors are warped bad enough, it is not unusual for the tire/wheel and steering wheel shimmy to be severe.
But, I'm on your side in this turmoil. Your situation needs to be addressed by the dealer. Continue to pursue that.....reasonably. Based on the latest TSB, you SHOULD get new rotors (mandatory) after 2 resufacings.
voigtsga
12
Oct 7, 2010 01:17 AM
