Lost Compression
Old Jun 30, 2023 | 05:57 AM
  #41
Oldsman's Avatar
I don't remember seeing this particular dowl either. It would make sense that it's a spacer, they usually don't come out. I'll let you know.
Old Jun 30, 2023 | 08:23 AM
  #42
Oldsman's Avatar
It did come out of the intake. Another instance of can't see the forest for the trees. I had already put the intake in a box. I wasn't thinking about it anymore.
Now to put it back together and see if there's a different outcome.
Old Jun 30, 2023 | 10:16 AM
  #43
Fingers crossed!
Old Jul 10, 2023 | 12:19 PM
  #44
Oldsman's Avatar
Lost Compression, WRONG CAM
Does anybody have a sorce for a 12621516 intake cam? I've ordered 3 intake cams and none where correct. After contacting my local GM parts distributor I got the correct part number but it's no longer available through GM. The aftermarket is no help and has bad information. I can't find this cam so far. I would appreciate if someone had a sorce for an intake cam for an 09 vvt, LE8, flex fuel, B engine designation alternative intake cam.
Old Jul 10, 2023 | 01:27 PM
  #45
No, sorry, I’m drawing blanks on that camshaft.
Old Jul 10, 2023 | 04:14 PM
  #46
Why are you replacing cams? I don't know what could destroy one without malice. The only thing touching them are the bearings and the rollers.
A machine shop would be able to fix anything but a broken one, probably point you to a source, if you insist.
Old Jul 10, 2023 | 04:18 PM
  #47
Oldsman's Avatar
Bad cam
They are rusted from sitting and condensation. It is a motor out of a wrecked car. I didn't want to reuse them.
Old Jul 11, 2023 | 07:59 AM
  #48
scrubby + motor oil. I can't imagine more than surface rust on the bearing surfaces. Your money.
Old Jul 11, 2023 | 04:10 PM
  #49
I’m thinking same thing as Donbrew posted
maybe post a photo of the cams
Old Jul 11, 2023 | 04:29 PM
  #50
You could call up the wrecking yards and see if they’ve got any “parts” motors laying around. Most larger yards have non salvageable engines they use for engine parts.
