Serpentine belt keeps falling
Old May 17, 2015 | 07:25 PM
I wonder, if the crank pulley was left on the Malibu engine, and the A/C and the alt pulley are from the HHR, could it be that a smaller belt is required? Do you have the original HHR crank pulley to measure the diameter or the circumference to see if it matches the Malibu pulley?
I hope I got that correct.
Old May 18, 2015 | 05:57 AM
Lucky's Avatar
I did a little research a found aftermarket crank pulleys are the same from Malibu to hhr but if you look up a Delphi a/c compressor the Malibu is cs20063 and the hhr is cs10077.
I wonder if the a/c clutch is different?
So my question would be did you reuse the hhr a/c compressor for the install?
Old May 18, 2015 | 09:33 AM
What about alternators? I have a feeling the Malibu would be different.
Old May 18, 2015 | 05:41 PM
Lucky's Avatar
Good point. I looked that up and there are two different part numbers for hhr and Malibu
Old May 19, 2015 | 10:38 AM
So then the alt pulley may be the culprit!
Old May 19, 2015 | 04:27 PM
Mmgsxr750's Avatar
I'll Check on that, thanx guys
Old May 19, 2015 | 05:57 PM
Let us know !
Old May 24, 2015 | 04:48 PM
Mmgsxr750's Avatar
Well fellas it turns out the ac compressor was missing 2 bolts, and it was starting to lean to the side. I guess the mechanic who did the engine swap didn't put all the bolts on. Just started running it today, hopefully this was the cause of the belt coming off, thanx for the help though guys
Old May 24, 2015 | 09:38 PM
Lucky's Avatar
Glad to here you got it figured out. Sound like an easy repair.
Dwarf7az
Maintenance and Upkeep
Oct 11, 2013 11:04 AM
Chevy_dork04
Aug 16, 2013 02:09 PM
intofocuszx3
Apr 19, 2013 08:07 PM
Timbo41
Feb 3, 2013 10:39 AM
RICANBABY
Jul 28, 2007 08:15 PM
