Won't start
Old Oct 10, 2019 | 10:57 AM
  #101
charliehines's Avatar
Lube but no cam bolts. Can I locktite these ?
Old Oct 10, 2019 | 11:23 AM
  #102
Most people reuse them.
Old Oct 10, 2019 | 03:46 PM
  #103
Thanks Don. I think I'm going to pull this head again since I tried starting it so many times with the wrong cams just to check the valves and pistons.
Old Oct 10, 2019 | 03:47 PM
  #104
lol I'm getting really good at this.lmao
Old Oct 10, 2019 | 04:32 PM
  #105
Yes. Good idea. If there is any fresh marks on the pistons, no matter how small or minor, then there could be some bent valves. Doesn't take much to put a small bend in the valve stem.
If you have any doubts about the valves being slightly bent. With the head off and flipped over you could do the old school " fill the combustion chamber with fluid and look for leakage"
Old Oct 10, 2019 | 06:18 PM
  #106
You can reuse the cam bolts and the head bolts, they are TTY so be careful on final tightening!
Old Oct 10, 2019 | 07:11 PM
  #107
I think it would be easier to install the new cams, and then do a leak down test. Actually, I would do it before I put the cams in, if there's leakage into the crankcase, cut your losses, get a new or used engine.
Old Oct 10, 2019 | 09:25 PM
  #108
GM recommends discarding most bolts. Nowhere do they say they are stretch bolts. I don't recall seeing any special markings on the head of the bolts, not even hardness. The torque spec being a torque plus torque angle is NOT make it TTY, that is just a more accurate way of doing it.
No way 22 lb. ft. + 100 degrees is going to stretch those bolts.
Make sure the threads are clean on both surfaces and not damaged. The important part is getting the base torque accurately set. Don't use anti seize or locktite very light application of motor oil to get an accurate base torque.
If you want to call them TTY do not use lock tite use a light coat of oil. If you use ARP bolts be sure to use ARP lubricant and the torque spec supplied by ARP not the manufacturer.
For your reading pleasure:
https://www.onallcylinders.com/2016/...gle-fastening/
Old Oct 11, 2019 | 11:01 AM
  #109
And all these years I’ve tossed out cam sprocket bolts crank balancer bolts and stuff, who knew?
Old Oct 13, 2019 | 06:56 AM
  #110
2011 hhr
P.S. I will be coming back
