How to reset ECM after a performance Mod.
Old Aug 20, 2011 | 05:33 PM
I think they might notice that its a different HHR than they expect to see when a black one rolls in with me behind the wheel Kev. Something tells me that they'll pick on the different model year, interior color, wheels, transmission, etc.
Old Aug 20, 2011 | 05:34 PM
LawDog88's Avatar
Well darn..
Old Aug 20, 2011 | 06:36 PM
jay loukakis's Avatar
Mike..
Jay, what kind of HHR do you have? 2.2 or 2.4?
My HHr a 2006 2lt, 2.4
Old Aug 20, 2011 | 09:40 PM
Fuse #43 is the TCM if you have an auto..... Not sure how much the tranny "learns" but that would also be suggested for an auto......
By pulling those fuses you just clear those two modules...... radio and other stuff stays unaffected.
X 2, precisely what I did, pulled (# 41 & # 43) when I added the gmpp air box..
Old Aug 23, 2011 | 08:24 AM
GOLFHHR's Avatar
Originally Posted by jay loukakis
I went to the Chevy dealer to reprogram my ECM $92.00 there was 21 uogrades.
When you had the dealer update the ECM did you notice any improvement in performance etc.
Old Aug 23, 2011 | 08:45 AM
Made a big change on the way home was doinr 70 mph, on the fwy. gas mileage was 34 mpg. performance was better.
Old Aug 23, 2011 | 04:33 PM
tracy waddell's Avatar
Greybeard, i have a automatic, what exactly happens when you pull fuse #41 & #43?.
Old Aug 23, 2011 | 04:58 PM
Blue_SS's Avatar
If you cut the power to the ECM, it reverts to its default settings, and then goes into learning mode, as it "learns" how you drive. So, if you drive like a nut right afterwards, it will be prepared for that in the future - you know, just in case...
I always did this by disconnecting the neg battery cable, but I guess this is easier than digging around in your rear end for the battery connection. (double entendre intended)
Old Aug 23, 2011 | 05:05 PM
Exactly? I'm not sure,
In short, it's the same as disconnecting the battery after a mod, but it doesn't effect the whole car...
#41 will reset the learndown feature of the engine and you will probably notice better throttle response, especially after a mod such as a different intake. It was night and day when I put on the GMPP..... I dove it before pulling the fuse and there was a huge bog just off idle...... Went away after pulling the fuse for 15-20 minutes and then putting it back. (Not a pull the fuse and leave it out mod..... Just a reset)
#43 would do the same IF! the trans has the same learning feature.... I think it tries to remember your driving style and set shift points accordingly, BUT I've never read that the tranny has "learndown" features. I have read reciently that this is also something to do with a change to the GMPP, maybe it's from the instructions???, I don't know. (never got instructions with mine) I didn't do this initially when I did the GMPP.
Learndown tries to learn your driving style and make adjustments to get the best mileage for you, or something to that effect..... That's not necessarily the best "performance". I've heard guys say that after pulling the fuse, "drive it like you stole it" and it learns that as your "driving style". I donno. I think the learning feature is going to learn part throttle "city driving", not wide open throttle. I just set it back to factory "new" settings and drove as I normally do..... aggressive!!!
When I had the Trifecta tune I told Vince to remove learndown as that was one of the options, not positive he did but it was in my requests. The last time I pulled both of those fuses I felt no difference, I believe that's because of the tune.
Old Aug 23, 2011 | 09:05 PM
speedwagen's Avatar
thanks Greybeard, That helps me understand whats going on.
I found CAI off of a SCION at a second hand store for 4 bucks.
It gives me quite a bit of extra tubing to fiddle with.
I am hoping to be able to plumb my filter into the fender well...as soon as my CGS gets here.
