Custom shift knob my HHR's automatic transmission!!!
Old Feb 4, 2008 | 12:15 PM
wingfeather's Avatar
I finally did it
Old Feb 4, 2008 | 12:16 PM
Wow, that's big
Old Feb 4, 2008 | 12:19 PM
millpond2's Avatar
And, how did you do it? Was it a DIY project, or a purchased piece? Am interested in some details.
Old Feb 4, 2008 | 01:23 PM
Magic!
It was part DIY, part purchase. Some of my methodology owes thanks to "CJ".
I found a shift knob (intended for a manual transmission) which was made by Autologix. It fit well onto the metal rod that the stock knob attaches to. Since the auto trans requires a button to be pushed to shift (and to get your keys out of the ignition), I had to come up with a way to push the inner part of the rod down (it has a plastic dowel in there). Through some experimentation, I found a metal spacer that fit the inner diameter of the rod & would allow for engaging the button (which no longer exists) by pushing down on the dice, which in turn pushes the spacer & then the plastic dowel.
It takes some work... but it's well worth it
Wow, that's big
Ha! It's actually smaller than I had hoped... my fault for not reading the dimensions before ordering. I had envisioned a huge rat rod shifter. I'd like to extend the metal rod, so the knob is just below my eye level, but that would totally block the cupholders when in "D"
Old Feb 4, 2008 | 07:56 PM
millpond2's Avatar
Originally Posted by wingfeather
Magic!
Thanks for the info. Nice job!
Lethal Tendencies
35
May 15, 2023 07:00 AM
HHHRgirl619
14
Sep 23, 2010 09:36 PM
crc
Jul 20, 2010 08:23 PM
Jeff®
Jun 17, 2008 07:42 AM
wingfeather
Jan 21, 2008 10:31 AM
