Disassembled Headlight
Old Dec 1, 2008 | 01:34 AM
  #41
Digital_Rapture's Avatar
im jellouss. i want those headlights
I second that.
Old Dec 1, 2008 | 01:45 AM
  #42
08BlkSS's Avatar
That looks SICK man .....I have been throwing the idea of doing this around for some time now and after seeing yours I am def gonna do it...just hopefully I will get some time to....looking forward to your how to on removing the bumper.....and did you say you got your extra set of headlights off of ebay?
Old Dec 1, 2008 | 06:52 AM
  #43
halfpanel08's Avatar
andrew!!! i looked on ebay. you can get a set of headlights for like 100$ on ebay.. then take those apart, paint em, ect.. then remove you bumper and just make a swap... THEN sell me yours when you take those out and ill do the same
Old Dec 1, 2008 | 11:29 AM
  #44
R CA HHR's Avatar
I don't see the finished product? Where are they?
Old Dec 1, 2008 | 12:29 PM
  #45
DLVRNIT's Avatar
Here's Pictures of the Finished Product Installed !
https://www.chevyhhr.net/forums/show...TED+HEADLIGHTS
Old Dec 1, 2008 | 04:08 PM
  #46
1Panel2NV's Avatar
Yep, that's it, thanks. I need to get some more pictures though.
Headlights are more like $100 each on ebay, besides damaged ones.
Originally Posted by Rcflyboy
If you haven't found a glue already, you can get CA at your local hobby shop. A 1 ounce bottle will be more than enough. About $10. You would want medium or thick formula so it does not run. You must also be carefull or the fumes will smoke the plastic.
ca glue won't work because it gets too hard and isn't meant to make an airtight seal. I ended up using silicone gasket maker.
DaveB
Aug 24, 2019 12:58 PM
Double0
"How To" Tutorial Library
Oct 12, 2011 04:34 AM
saxrocks2009
May 17, 2011 09:58 PM
james france
Maintenance and Upkeep
Dec 2, 2010 06:35 PM
HHRcheater
7
Nov 14, 2007 04:43 PM
