LED wash
Old Jan 25, 2011 | 06:44 AM
LawDog88's Avatar
LED wash
HillsdaleHHR or ChevyMgr, do either of you know the cost of the led that goes in the light wash on the console?
I want to get a pair of these and wire them into the fog lights, and put them in the head lights. If I can get this to work, I will show you all.. :) PM if you want the deets.
Old Jan 25, 2011 | 07:26 AM
LawDog88's Avatar
Anyone can answer, I just figured they might know.
Old Jan 25, 2011 | 07:29 AM
Nothing special about the LED 1151, its a standard 5mm unit. You can pull it out and take it into Radio Shack and they can match it up for you, they probably also have a socket that pretty much matches the factory socket. A couple of folks here have changed the color of theirs by going the Radio Shack route, just trim the leads to the same length and pop it in the socket. Hope this helps.
Old Jan 25, 2011 | 07:33 AM
LawDog88's Avatar
Would I need one for mounting inside of my headlights? Or just silicone it in and wire it up?
Old Jan 25, 2011 | 07:59 AM
Well they have LED holders available(see the attached pics), that will fit the 5mm LED's for $1.49 ea. You'd have to drill the headlamp reflector in order to use them. I guess it depends on the look you're going for, and how finished you want it to look. If you don't mind me asking, what are you going to use them for? Are you going for the euro look with LED running lights, or something else?
Timb727
Maintenance and Upkeep
Apr 19, 2012 11:30 AM
FXM
22
Sep 8, 2010 05:30 AM
oneton
Apr 19, 2009 10:57 AM
SIHHR
21
Dec 17, 2005 02:45 PM
