Smoothie HHR Door Lock Knobs
Old Jul 30, 2006 | 09:36 PM
courthousedeb's Avatar
The search function is your best friend here. Used the term smoothie door and came up with the following threads.
https://www.chevyhhr.net/forums/showthread.php?t=3501
https://www.chevyhhr.net/forums/mods-interior-54/door-lock-write-up-1606/
Old May 21, 2007 | 11:58 AM
jaime_g's Avatar
where can i still get them?
Where can I still get the smoothie door locks?!?!
Old May 21, 2007 | 12:27 PM
Just go to your local parts store and pick out a set you like. I'd run with them a couple days before gluing to see whay height adjustment, if any, you need to make. Then glue them in.
With mine, I found they wer good with no cutting. Plus it left enough to grap if for some reason you loose power.
Old May 21, 2007 | 03:38 PM
Size:  5.6 KB to the site!!! Some members have just cut down their stock door locks and reused them too.
Old May 21, 2007 | 03:46 PM
ivtech's Avatar
Also Ford F-150 uses black ones that someone has used.
Old May 26, 2007 | 12:53 AM
  #26
jaime_g's Avatar
thanks for the welcome! is this a risky install? cutting down the existing ones and reusing them? does anyone know how to remove the door panel?
you guys are a great help!
Old May 26, 2007 | 12:56 AM
  #27
Door panel does not need to come off for stubby locks.
  #28
No need to remove the door panel for this. Just roll down your window and unlock the locks. I don't know anything about cutting down the stock. I'd say go to you local parts store and pick up a set you like. I'd try them first without cutting, the smooties I got were fine w/o cutting. You can always cut later, but once you cut, your comitted.
Old May 26, 2007 | 01:03 AM
  #29
jaime_g's Avatar
you can get smoothies from a local parts store?! i must be hangin' out in the lame section of the parts store, because i don't see them anywhere!
Old May 26, 2007 | 01:07 AM
  #30
OK, time to get out of the PT section!!
