Smoothie HHR Door Lock Knobs
The search function is your best friend here. Used the term smoothie door and came up with the following threads.
https://www.chevyhhr.net/forums/showthread.php?t=3501
https://www.chevyhhr.net/forums/mods-interior-54/door-lock-write-up-1606/
Just go to your local parts store and pick out a set you like. I'd run with them a couple days before gluing to see whay height adjustment, if any, you need to make. Then glue them in.
With mine, I found they wer good with no cutting. Plus it left enough to grap if for some reason you loose power.
No need to remove the door panel for this. Just roll down your window and unlock the locks. I don't know anything about cutting down the stock. I'd say go to you local parts store and pick up a set you like. I'd try them first without cutting, the smooties I got were fine w/o cutting. You can always cut later, but once you cut, your comitted.
to the site!!! Some members have just cut down their stock door locks and reused them too.
