2 12's build
Old Sep 7, 2010 | 09:35 PM
ufvj217's Avatar
ufvj217's Avatar
Old Sep 7, 2010 | 09:38 PM
ufvj217's Avatar
Old Sep 7, 2010 | 09:39 PM
ufvj217's Avatar
ufvj217's Avatar
Old Sep 7, 2010 | 09:40 PM
  #26
ufvj217's Avatar
heres a diagram of the setup. i was gonna run other 6's but they dont make them anymore, so i put eminence 6a's in the diagram. might run selenium or others, not sure yet. but for sure itll be 6" and 8ohm.
all 8 mids will be wired together (4 in parallel on ch1 @ 2 ohm, 4 in parallel on ch2 @ 2 ohm) getting about 62w per mid.
the 2 horns will be wired in with the 6 tweets on ch 3/4 the same as the mids (1 horn 3 tweets in parallel per channel @ 2 ohm, getting 62w each). reason i wired the horns in with the tweets is becuase ch1/2 will be set lower, and since the horns are rated to play from 400hz up, i can set the filter on ch3/4 to 400, and it wont affect the tweets (didnt want to set it that high on ch1/2, becuase i want my mids playing lower than 400hz)
http://img.photobucket.com/albums/v1...hs_diagram.jpg
Old Sep 7, 2010 | 09:41 PM
  #27
ufvj217's Avatar
Old Sep 7, 2010 | 09:42 PM
  #28
ufvj217's Avatar
Old Sep 8, 2010 | 03:23 PM
  #29
Gas Man's Avatar
WOW that is great. But damn those links suck!
Enable clickable thumbnails in your PB settings. Then post those...
I know why you aren't IMG tagging them cause they are "too big". But the links suck.
Old Sep 8, 2010 | 03:48 PM
  #30
ufvj217's Avatar
lemme enable that real quick. lol
but thanks :)
i just put a layer of resin on the pods. pics later!
