Amp mount ideas
adjust the gains on your amp. Set them as low as you can then turn on your stereo to half way. Start your car and then slowly turn your gains back up. If you start to hear the whine again then slowly turn them back down a little.
Let us know about the optima. Because it's been suggested not to use one because the battery can't "breathe" back under the trunk. (even though the optimas are SEALED...I think they CAN vent, correct?)
Anyway, I'd love to put a yellow top in mine...but also want to be safe.
I don't remember what model it is. It went in pretty easy. Maybe a little finagling with the ground wire but all in all real easy. I think its harder to pull out the spare tire than it is to get the Optima to hook up.
GDZHHR has a gel cell in his ride also. Its not an Optima but it does the trick.
Ok so I swapped batteries with my wife. Yeah umm. still have the same problem. Now I get to disconnect the battery ground from the body to scrape off the primer and see if that helps any.
