Amp popping
Old Mar 30, 2007 | 01:28 PM
Originally Posted by BIGJP
Is the software upgrade needed if a aftermarket radio and GMOS LAN3 adaptor? Ever since I installed this I get a pop from my left front speaker when chime completes.
That sounds more like an install issue to me. A flash wouldn't help you since you don't have the factory radio to flash. I'd take it back to where you had the install done.
Old Mar 30, 2007 | 04:26 PM
dbarberaz's Avatar
Have to agree, the softwarte flash is only going to work on a stock radio. I have had no problems once I changed out my radio
Old Mar 30, 2007 | 05:56 PM
rewcolee1's Avatar
I do have alot of work on installing into 00 and gm autos. That is a common problem with the Lan adaptors in general. I have yet to find a fix for this execept to make sure that all connections are proper and if that doesn't fix the issue then if possible and you are willing try a new one.
mankin5344
Feb 10, 2015 11:23 AM
Daytonablue06
Jul 8, 2010 07:31 AM
mightymouse
Jul 11, 2008 09:10 PM
pontfirebird73
Jul 17, 2006 10:49 AM
