Help needed - middle of install - poor speaker sound quality
Old Apr 19, 2010 | 08:01 AM
prod's Avatar
The instructions for using the harness with the factory amp are pretty clear, use the RCA connections, not the speaker wires. Is that how you have it wired now?
Old Apr 19, 2010 | 08:33 AM
techguy's Avatar
Heres a thought ...
Maybe stop by a local Stereo Shop .. See what they can do for you ..
Old Apr 19, 2010 | 07:04 PM
jgoldwood's Avatar
Yes, I have it hooked up just as the directions say to do - RCA connections and not the speaker wires.
Old Apr 20, 2010 | 08:43 PM
RFT's Avatar
RFT
Originally Posted by jgoldwood
Thanks again. The pop happens anytime the car has a chime sound - locking the doors, keys in the ignition with the drivers door, etc.
Yeah, still sounds like it is the adapter causing the problem...
Honestly, I'm getting to the point where I too don't care if I lose the chimes and XM. The LAN-04 is terrible. Does the cheaper adapter work more like a normal adapter - you attach all of the speakers to the harnesses speaker cables instead of using the RCAs that the LAN-04 utilizes? Did you have the premium sound?
Yes, it does work like a normal/older adapter as you hook up to the speaker leads. I didn't get the premium as I knew I would be gutting the system after XM expired. Low and behold, on the first day after XM expired I started removing panels.
canroc
May 5, 2015 03:10 PM
Bahta
Apr 29, 2015 11:43 AM
slimsol
Jul 5, 2010 11:01 AM
beachbum1970
Jun 4, 2009 04:45 PM
giant96
Jul 14, 2006 06:23 PM
