The how to for installing a double din radio on 2010
Old Jun 28, 2012 | 05:48 PM
paulstanley19147's Avatar
Hi there I have been a mechanic for 8yrs now and never messed around with installing aftermarket radio units but I followed the how to on removing the stock radio and wanted to tell everyone it is a little different on the 2010, the main cover, the little side panels and the cig lighter are all one piece, so when following the how to it says to remove the two side trim panels then the main center cover then the cig lighter assembly, on the 2010 atleast it is all one piece so be careful not to break your dash apart and you also need to pull out the silver piece or the "change holder" and remove two screws under it to be able to put back the dash if anyone has questions I'll do my best to help but you will have to cut out part of the inner dash as well, sounds worse then it actually is
nismo_8803
Jul 3, 2014 08:05 PM
nacademus
Mar 24, 2011 05:20 PM
HHR Rock's
Mar 6, 2007 05:31 PM
laylowcustoms
May 14, 2006 05:52 PM
