JL Audio clean sweep
Old Jul 14, 2006 | 09:30 PM
bowtiebubba's Avatar
Could someone explain this jl audio clean sweep thing to a novice? What and how it would work in my HHR? Thanks guys
Old Jul 15, 2006 | 06:21 AM
JOEK86's Avatar
The CS is a line level driver, it increases and sums the signal from you stock Head Unit so that you do not have to turn up the gains on your amp to compensate for a low signal. This prevents amp distortion. This unit works very well, but the down side is that it has it's own master volume. You would set the HU's volume using a set up disc. After that is done, the CS's master volume would be used as your main volume control. If someone accidently moves the old volume control you would have to go through the set up sequence again, kind of a pain in the A. Also, you have a seperate added control to mount somewhere on the dash.
I would suggest looking at Audiocontrol's Linedriver, they are great and only use your existing volume control.
Or take the $300 - $400 that these devices cost and get a better after market head unit, they sound way better and and have some additional features that are of use!
Joe
Old Jul 15, 2006 | 07:16 AM
cj krause's Avatar
when i saw the price i am going
h/u or clean sweep
i am going w the head unit in October when onstar is done
pioneer 9800BT
woooooooooot
Old Jul 15, 2006 | 06:02 PM
Lefty613's Avatar
i put a clean sweep in my uncles ml cus he wanted to keep the stock look... its far better then an avg line driver... but money should allways be an issue
Lethal Tendencies
May 9, 2024 10:57 AM
HillsdaleHHR
7
Sep 4, 2013 12:44 PM
Lone Ranger
Jun 29, 2007 09:12 PM
DYLANSHHR
Oct 4, 2006 02:26 PM
