Using your stock door speaker adapters
Old Jan 29, 2015 | 07:59 AM
RichW's Avatar
Originally Posted by agmc4me
Thanks for the reply and the info. I had replaced the fronts in my impala the other year and left the factory tweeter hooked up. It is right next to the 6.5" speaker. Seemed the result was too much tweeter. I don't drive it anymore since I got the HHR. I put infinity speakers in that, maybe I'll use them in the HHR. Just for knowledge would cutting the tweeter wire out of a coax make the resistance more compatible with the factory stereo?
P.S. where did you get the half hat from?
I'm not sure how much the impedance would change. If you're leaving in the factory tweeters, then cutting the tweeter wire on the coaxial unit should compensate for this setup. Nice thing is you can try it and re-connect if you don't like the result.
I buy the hats from Crutchfield and cut them in half. I found the full hat deadened the bass.
Rich
bryceramos
Aug 2, 2013 12:57 PM
STLracerX
Aug 5, 2009 06:30 PM
thedonn007
Apr 6, 2008 01:08 PM
