Various HHR Sub Installs...
Old Jan 4, 2008 | 09:19 PM
  #111
a2race's Avatar
i have a base model LS with the base stereo/cd player w/6 speakers.......i have an amp, and i wanted to use an 8" kicker speaker.....will those work in the stock location? is the enclosure put in all of the HHRs even when factory sub is NOT used? where could i pull off the switchable power for the amp, and where i can locate the rear speaker wire for the signal to the amp? adam
Old Jan 5, 2008 | 07:25 PM
  #112
mcs's Avatar
mcs
We finished our project car for the local dealer and the sub install turned out pretty impressive... check out this thread:
https://www.chevyhhr.net/forums/audio-video-17/very-custom-hhr-install-local-car-dealer-12049/
Hope you find it interesting.
thanks
Old Jan 5, 2008 | 08:20 PM
  #113
quest51210's Avatar
No offense Lee, but you are pretty redneck
Old Jan 11, 2008 | 08:06 AM
  #114
Lee3333's Avatar
No offensed taken-but why???
Perhaps the bungee/sub hold down? That was just a temporary fix-replaced by something even sillier-. I am searching for the right answer, and will eventually find it.
My attempt here was to have the tube hinged so it would pivot up and make access to the bottom area easier. Sadly, with the tube the long way I cannot fit a take-out pizza box in the back-so the search continues... I am thinking about building a box that is wide and shallow and would fit on top of the PVC, like a 6 inch high shelf with 2 subs in it firing down. I could put things on top or below it. Or a smaller box for just 1 sub that would rest on the window ledge. My brain is flooded with ideas!
Note the new MTX 280 Watt amp :)
Old Jan 11, 2008 | 04:18 PM
  #115
stick's Avatar
Hey, don't knock it. Atleast you are doing your own thing and not following everyone elses ideas. Remember as the billboards say......on the ten thousandth time there was light......
Old Jan 28, 2008 | 01:03 PM
  #116
Ed RazorLite's Avatar
Old Jan 28, 2008 | 01:04 PM
  #117
  #118
Old Jan 28, 2008 | 01:09 PM
  #119
Here is a nice Woofer
Old Jan 28, 2008 | 01:11 PM
  #120
By the way, has anyone here had their sunroof brace break due to the roof flexing? Once I get up to 150 dB, the roof flexes about 1.5" and the sunroof broke. I just fixed it and reinforced it so I dont have that issue anymore. Just want to warn people about it.
