Various HHR Sub Installs...
Old Mar 17, 2012 | 03:31 AM
  #291
07azhhr's Avatar
One other thing to note about the Polk MM's is that when I model the Morel 10 and the Polk 8 using the same box and the same wattage (225w) the SPL plots are almost identical. Also worth mentioning is that the 8 actually models +1 db higher below 35hz while the Morel is +1db higher above 38hz so these Polk MM 8's are very close to 10's and the 10's are more in the leagues of 12's. Polk did an awesome job with these subs IMHO.
The only reason that I want to use the Morel 10 at this point is that I will be able to feed it 600 watts and achieve the same SPL (has 95db sens rating) that I am getting right now from the 2 8's in seperate boxes. This will allow me to use one box behind the interior panel and get the SPL I desire. If these 8's handled more wattage I would probably be able to run 1 and get the output that I expect to get with the 10.
Old Mar 17, 2012 | 01:41 PM
  #292
Joshua022's Avatar
Originally Posted by lunchbox
I installed 8" Rockford P2s under the front seats of my panel. Custom made some mdf and fiberglass boxes, fit perfect and sound good too. Gotta take some pics of that. Also about to wall off the panel for 4 18" subs, I'll keep y'all posted
do you have any pics of the subs/boxes under your front seats?
Old Mar 24, 2012 | 01:42 AM
  #293
jeff schaffer's Avatar
Transformer HHR AUDIO SETUP
Old Mar 24, 2012 | 01:45 AM
  #294
Led's Upgrade pics!
Old Mar 24, 2012 | 01:47 AM
  #295
last pic layout lit up.
Old Mar 27, 2012 | 12:22 AM
  #296
Now you see it...
Old Mar 27, 2012 | 12:24 AM
  #297
now you dont! cargo space...?
Old Mar 27, 2012 | 07:04 AM
  #298
gscott1962's Avatar
My HHR
Id love to show you my HHR but i cant post pics? I figured it out?Here she is!
Old Mar 29, 2012 | 04:03 AM
  #299
Nice...
Old Mar 29, 2012 | 08:47 AM
  #300
zap-mann's Avatar
gscott you have any pics of the front doors?
