Wiring for Pioneer radio into 09 HHR
Old Apr 11, 2022 | 08:59 AM
  #51
It is easy to tap a switched (RAP) circuit from any of the "unused" fuses on the BCM. The RAP is what controls the "on for 10 minutes" function.
Old Dec 1, 2022 | 09:02 PM
  #52
jthhr2007's Avatar
gmos lan 04?
does anyone know on the axesss lan 04 what the 3. 5 auxiliary cable is for what do i do with it
Old Dec 1, 2022 | 09:20 PM
  #53
hhrumadbruh's Avatar
What is your yead unit? Does it have a 2.5mm or 3.5mm with "SW" on it?
some units use thr 3.5mm plug and some use a wire for steering wheel control.
Check the sw control manual.
Old Dec 1, 2022 | 09:27 PM
  #54
jthhr2007's Avatar
i opted out of the steering wheel controls
Old Dec 2, 2022 | 08:06 AM
  #55
This is from the instructions available online at https://metra-static.s3.amazonaws.co...LAN-04_web.pdf
And this from the ASWC-1 instructions at https://metra-static.s3.amazonaws.co...structions.pdf
Old Dec 3, 2022 | 03:56 PM
  #56
Cheap Guy's Avatar
I'm not understanding your question. I know Pioneer (and others) and Kenwood/JVC radios require a different connector with the kit to retain steering wheel controls. Pioneer, for example has a smaller aux jack to plug in the rear of the head unit. Just stick with the instructions for your particular radio and everything will go fine. The only issue I had was when I added a new steering wheel and Metro (Axxess) customer service helped me with that process.
hhrumadbruh
Dec 23, 2022 04:14 PM
Guso19
Dec 24, 2012 09:24 AM
BunglerHHr
Oct 12, 2012 01:00 AM
stick
Sep 5, 2008 07:11 PM
mudbilly
Sep 11, 2006 07:50 PM
