2 Inch Drop Causes Shudder
Old Jul 6, 2021 | 01:14 PM
Fire_Wessle's Avatar
Originally Posted by Oldblue
Floor jack and jack stands, 15 mm wrench or socket and ratchet, torque wrench.
if you changed the coil overs yourself, you can do this!
https://www.chevyhhr.net/forums/prob...problem-60373/
That spacer goes between the transmission mount and the frame of the car correct?
Old Jul 6, 2021 | 01:40 PM
Yes, the information is in the ZZP catalogue link
Old Jul 6, 2021 | 01:42 PM
Cool just wanted to double check
Old Jul 6, 2021 | 01:44 PM
Get those steering rack spacers installed also.
Old Jul 9, 2021 | 12:31 PM
Remove the three mount bolts from the rear transmission mount, jack up the transmission about 3/4 to an inch, insert the spacer, lower transmission, install the bolts and tighten them up by hand! Then torque them to spec , 89 ft/lbs
Sorry for all the extra questions, the spacer just came in today. Once I get the car on jack stands, where is the rear transmission mount located? What is a good spot on the transmission to place the floor jack? Do I need a flat plate to jack up the transmission to fit the spacer or will a normal floor jack not damage the bottom of the transmission? Again sorry for all the questions, I just don't wanna mess up my transmission
Old Jul 9, 2021 | 12:45 PM
Look for a triangle of three bolts from under the engine cradle, 15 mm hex head bolts
place a 2x4 under the transmission, do not attempt to lift the transmission more then an 1”
From the top passenger side you can see the rear transmission mount
From the top driver’s side , there it is
Old Jul 9, 2021 | 12:50 PM
Here’s a photo showing the triangle with the cradle out of the car for clarity, you don’t have to remove the cradle to install the spacer
Old Jul 9, 2021 | 01:04 PM
Awesome! Thank you so much! I should be able to get this installed sometime tomorrow
Old Jul 9, 2021 | 01:14 PM
Here’s more
This is from the passenger side with the steering rack removed to see the rear transmission mount on the cradle bracket, there in that circle highlighted
And from the driver’s side, that’s where you install the spacer Note: you don’t have to remove the steering rack, I just found these photos in my library.
Old Jul 10, 2021 | 01:01 PM
Update
The transmission mount spacer worked! Far easier to do than I expected. The only issue I ran into was I didn't have the leverage to properly torque the bolts down (I didn't have a big enough pipe to fit on my torque wrench, but I still got them tight enough). If I had a lift it would have been much easier but harbor freight jack stands did the trick.
As far as the rack spacers, I was not able to install them. I did not have the proper extentions to reach it (or maybe I'm just dumb and wasn't thinking hard enough). There hasn't been much of an issue with bump steer so I'm not too concerned about waiting a bit longer. I do still intend on installing them in the future but mabey I'll just have a garage install them and align it for me all at once, I definitly need an alignment. Thanks again Oldblue, your a life saver!
