brake problems
Old Dec 7, 2006 | 06:49 PM
Snoopy's Avatar
People who are experiencing rotor trouble need to inform their dealer of the TSB that GM has on this problem.
This TSB has been out since about spring and revised EIGHT times. It is TSB # 00-05-22-002G, dated 8/8/06 (for some reason this TSB is not showing up in AllData).
GM has discovered that dealers, for some reason, are not following the procedures established in that TSB.
If you have had continual rotor problems and returned to the dealer for "cutting", GM is probably telling the dealer they did not follow procedure, so it is at dealers expense to repair. That may be why the dealers are saying can't do anything.
Last paragraph is my opinion...the rest is factual.
Old Dec 7, 2006 | 10:28 PM
ny5112's Avatar
do u have a link for it if so can u post thanxs
Old Dec 7, 2006 | 11:09 PM
Snoopy's Avatar
No, I cannot link it.
However, if the Administrator of this forum approves, I may be able to copy and post the information. It is extensive..probably about 11 pages
Edit.....Disregard....I'm not able to copy and print either. But, I have just noticed that there is an update to the TSB I gave you. It is now the same number but with an "H" at the end.
TSB 00-05-22-002H
Old Dec 9, 2006 | 07:45 PM
crowbar's Avatar
8000 miles, my brakes are shot to hell. rotor warp shake is horrible and pads are squeeling bad. hhr brakes=junk
Old Dec 28, 2006 | 09:41 PM
wrusprod's Avatar
12000 miles....same problem...normal driving dont notice it. but when I'm on the Highway and brake the steering wheel shakes...im going to the dealership tomorrow to see what they plan to do.
Old Dec 29, 2006 | 09:17 PM
wrusprod's Avatar
well they turned them,as I thought they would...They said wasnt warped but Rust on surface...(will see). but at least they didnt charge me. probably will upgrade to heavier rotors after warranty period..
Old Dec 29, 2006 | 09:28 PM
Black Rose's Avatar
Brake pads and rotors normally aren't covered by warranty, unless there are issues with premature pad wear or rotor issues that show up within a certain amount of time. Once you go past a certain mileage value they won't do it anymore.
drspock
Aug 11, 2023 04:08 PM
walkowg
Jun 16, 2013 08:08 AM
10RedSS
Jan 21, 2011 09:17 PM
Clevelandhhrss
Jan 5, 2009 08:03 PM
REDHHRSS
Aug 14, 2008 09:29 AM
