Brembos up front, Disc Rear on 06 2LT
Old May 13, 2018 | 10:56 PM
  #121
Lonwane's Avatar
Working on doing the same to my '06 2LT. Replacing the bushings is turning into a pain but I will succeed.
Old May 13, 2018 | 11:31 PM
  #122
Cody51's Avatar
There is a Thread for that
There is a thread about replaceing the rear axle bushings titled "Removal of Rear axle bushings" that is very good. It was started on 08-09-2016 at 10:13 PM by ULOS2A6 check it out it may help..
Old May 14, 2018 | 08:38 AM
  #123
You can borrow a tool from Advance/Zone.
Name:  rear bushing tool.PNG
Old May 14, 2018 | 09:03 AM
  #124
Cody51's Avatar
Tool
Attachment 47006
A tool would be great, Thank You
Old May 16, 2018 | 08:42 AM
  #125
pbatmen's Avatar
Originally Posted by pettyrules
About what was the cost of the rear disc brake conversion, and where did you locate the kit?
Junk yards, internet are a great way to track the parts down. The HHR/Cobalt have been out of production now for a while so there should be some around in junk/salvage yards. I used a website called car-parts, its a junk yard website for parts, great way to track it down.
Old May 16, 2018 | 09:10 AM
  #126
Lonwane's Avatar
X2 with car-parts. ebay is also useful. I found my axle beam in St. Louis. Bushings and hubs - MOOG, brake discs, pads, rotors - PowerStop, brake lines, parking brake cables, hardware - Raybestos. Total cost of $850.00 plus time to install. Oh, and $200 for bushing tool J44570, which I now have and will let others use for the cost of shipping.
Old Jun 2, 2018 | 10:02 AM
  #127
flamarallenjr's Avatar
HHR 2011- does the same caliper bracket work for the larger rotors used with Brembo s
Originally Posted by American & Proud
Pics of the Rears and a HOW-TO !
I tried buying an SS rear axle but the junk yard never sent to pics before I drove the 200 miles to go buy it, so I moved on to other projects.
The Supercharger is going in before I add rear disks now.
But a good how to with part #'s included would be very cool if you did it without buying a SS rear axle.
Fronts look good.
Does the bracket used for regular SS brake caliper also work with Brembo caliper and the larger brake rotor setup?
Old Jun 2, 2018 | 04:48 PM
  #128
In a word no
SS caliper brackets non Brembo
Brembo calipers, you’ll need new brake hoses
But don’t be shy, go big!
14.5 inches diameter rotors, tuck nicely into 18” SS wheels
https://www.ebay.com/itm/ZZPerforman...3635746?_ul=CA
These look awesome
Old Jun 5, 2018 | 06:52 PM
  #129
phrog fixer's Avatar
Memorial weekend project, done. 07 HHR LT non-ABS, installed 07 Cobalt SS rear disc brakes.
Rear disc under stock 16" wheels.
Memorial weekend project, finally done after being on hold foe 4 years
Old Jun 5, 2018 | 07:46 PM
  #130
Nice work!
