Caliper to wheel allowable clearance?
Could someone tell me what the minimum clearance between the caliper & the wheel is? ('06 hhr LT1) I got a good deal and would like to use these 15" steel rims from an '05 malibu for my snow tires (gotta save the aluminums - great white [salty] north, eh!), but I've only got about 9 - 10mm (~3/8") between caliper & rim with the 15's on instead of the 30mm (~1-1/4") with my stock 16's. There doesn't seem to be any interference but I wonder if there would be problems when things heat up, such as under heavy braking. Insight, anyone?
My first question is are they the correct bolt pattern. I have asked a lot ob people and they all said that they were not. Let us know the dim. of the bolt pattern on the 05 malibu.
See ya down the road
Bud / Harvey
Bud / Harvey
The 04 - 06 malibu 15" wheel is the same specs except diameter (5-110mm bolt spacing, +42mm offset, 65.1mm hub, 6.5" rim width) I test-fitted a rim on the front and there doesn't seem to be any interference with the tie rod ends lock to lock, but like I said there is only 9 - 10mm clearance between the caliper and the inner surface of the rim. They do fit, but my concern is the lack of space between the caliper and the wheel. I know some racing applications have very minimal caliper to wheel spacing, but I don't know if that is permissible for the street.
While digging on the 'net, I found a site that has what stock wheels fit the HHR as well as their products. You'll find it at :
http://www.fastco.ca/web-content/Ima...06appguide.pdf
Aftermarket Wheels:
Here's the short list of stock wheels that will fit the HHR:
(Make/Model; Year(s); bolt circle; hub dia.; offset)
Chevy HHR 06 - 5x110mm; 65.1mm; +42mm
Cadillac Catera 96-01 - 5x110mm; 65.1mm; +51mm
Chevy Cobalt SS 05-06 - 5x110mm; 65.1mm; +49mm
Chevy Malibu/Malibu MAXX 04-06 - 5x110mm; 65.1mm; +42mm
Pontiac G6 05-06 - 5x110mm; 65.1mm; +42mm
Pontiac Pursuit GT 06 - 5x110mm; 65.1mm; +49mm
Pontiac Solstice 06 - 5x110mm; 65.1mm; +55mm
Saab 9-3 99-06 - 5x110mm; 65.1mm; +41mm
Saab 9-5 99-06 - 5x110mm; 65.1mm; +49mm
Saturn L-Series 01-05 - 5x110mm; 65.1mm; +45
Saturn Sky 06 - 5x110mm; 65.1mm; +55mm
Saturn Ion Redline 04-06 - 5x110mm; 70.3mm*; +49mm
*Wheels with hubs greater than 65.1mm may require a hub collar.
Aftermarket Wheels:
Originally Posted by JoeR
Pull your spare out and compare. That is a 15" steel wheel.
The other day I rotated my tires and used the spare to make things easier. The fit was tight, but GM must feel it's OK.
Good luck.
Good luck.
Aftermarket Wheels:
Aftermarket Wheels:
took me forever to refind it.
