Car wanders after new tires installed
Old Jun 21, 2020 | 11:54 PM
Silverfox's Avatar
It is hard to look at a tires tread and figure out if it could cause tire wander.
I put on a new set of Coopers and lost stabile straight tracking and Pulled left as well.
All tires pressures were double checked. OK @ 32 lbs. cold.
Spent a lot of time trying to track down if it was actually something else.
Gave up and made the take them back and put on the new set of Michelin Ice 3 because winter by then was approaching.
The car drove absolutely perfect and still does..
Tire design does matter.
Silevrfox
Old Jun 23, 2020 | 08:17 PM
kryptor's Avatar
Well I bought new LCA's now I just have to put them on to see if it solves the issue, for some reason I don't have faith since the car didnt do this behavior with the winter tires but the winters were a 205//55/16 where as the summers are 215/70/17 I wonder if the 215 over the 205 could amplify the wandering on the road with bad lca bushings since bushings were probably bad this winter as well but I didn't experience the wandering. I just hope the LCA fixes it since if it doesn't then I need to spend more money to buy some new tires again and try to sell these ones.
Old Jun 24, 2020 | 07:42 AM
Doc brown's Avatar
Just putting on new tires can reveal the wandering. The old tires get worked into a pattern like your shoes. Often you can't see it because it might be subtle but enough to think you are tracking normal. LCA bushings are a common wear item on HHRs.
Old Jun 24, 2020 | 08:50 AM
While you are in the neighborhood check the tie rods. You are replacing the ball joints with the LCAs anyway. Your struts are probably gone the don't last forever.
Old Jun 24, 2020 | 09:05 AM
kryptor's Avatar
Front struts and rear shocks are new, outer tie rod new rods are mew as well, stabilizer links are new as well.
Old Jun 24, 2020 | 12:22 PM
Then the LCA’s are the most suspect especially those rear bushings. You did order aluminum and not stamped steel, right.
Old Jun 24, 2020 | 12:33 PM
kryptor's Avatar
They are Mevotech supreme cast aluminum, the store didn't really give me an option of steel vs aluminum.
Old Jun 24, 2020 | 12:35 PM
Ok, cast aluminum. My choice is the Moog forged aluminum arms , a little less expensive and I am not familiar with the other brand
please post a photo or two and let us know how you would rate their quality , thanks
Old Jun 24, 2020 | 01:06 PM
Hmmm... I thought they were supposed to be forged aluminum.
Old Jun 24, 2020 | 03:11 PM
They are , however that could be a typographical error in terms.
