Car wanders after new tires installed
Old Oct 8, 2020 | 06:15 PM
  #41
If you had an align with the bad bushings and the broken rear coil springs, then your alignment will be out after you replace the parts.
Old Oct 8, 2020 | 08:56 PM
  #42
Bonez's Avatar
Originally Posted by kryptor
Well I bought new LCA's now I just have to put them on to see if it solves the issue, for some reason I don't have faith since the car didnt do this behavior with the winter tires but the winters were a 205//55/16 where as the summers are 215/70/17 I wonder if the 215 over the 205 could amplify the wandering on the road with bad lca bushings since bushings were probably bad this winter as well but I didn't experience the wandering. I just hope the LCA fixes it since if it doesn't then I need to spend more money to buy some new tires again and try to sell these ones.
wider tires have more drag
Old Oct 17, 2020 | 08:38 PM
  #43
kryptor's Avatar
Car is aligned now and it seems to be ok now.
Old Oct 18, 2020 | 11:22 AM
  #44
Awesome, thank you for the follow up
Old Jul 26, 2022 | 03:10 PM
  #45
Radco's Avatar
A old thread but very interesting ! :)
And nice seeing someone that Updates the work done !
Old Oct 25, 2022 | 08:08 AM
  #46
desertrat's Avatar
If the front caster angle is off the car will wander, tires won't cause this. An off-center steering wheel and be correct by adjusting the tie rod ends one direction or the other, equally, depending on which direction the steering wheel is turned.
Caster can be adjusted by installing aftermarket eccentric bolts where the strut bolts to the knuckle. One bolt per side, and the hole must be elongated to fit the bolt.
Old Oct 25, 2022 | 09:28 AM
  #47
If the struts and tie rod ends are tight and the ball joints and LCA bushings are good, then you only need to adjust the outer tie rods . No need for camber bolts
Old Oct 25, 2022 | 02:31 PM
  #48
Caster can only be adjusted by pulling the body. desertrat must have fat fingers.
Camber can be done with eccentric bolts or by drilling the holes on the struts. I needed to use the camber kits when the LCAs were too long, they can adjust about 1 degree.
DAVE YOUNG
Tires & Wheels
42
May 16, 2016 03:00 PM
Draper 06 HHR
Tires & Wheels
46
Apr 26, 2011 04:28 PM
3amigos
Tires & Wheels
13
Feb 22, 2010 06:36 AM
HHRANDY
Tires & Wheels
10
Jul 31, 2007 01:02 PM
lrg760
Tires & Wheels
22
Jun 4, 2007 08:45 PM
