Cold weather brings cool noises!
Old Nov 27, 2008 | 12:09 PM
bartSS's Avatar
I was about to make a post on this i thought that my front shocks went bad. But i did only notice it when it got in the 30s. So im glad that my shocks arent blown
Old Nov 27, 2008 | 07:07 PM
Painter's Avatar
Mine is exactly the same!
Old Nov 27, 2008 | 08:33 PM
stephenm's Avatar
Same here, cold weather it makes noise, warms up it goes away
Old Dec 2, 2008 | 11:22 AM
Gone Blue's Avatar
No suspension squeaks here. I had a periodic squeak in the drivers seat and another one I think that was coming from below the top center glove box that have dissappeared. I was thinking that they would have been worse and more repeatable when it go cold for the dealer to find. But the car is squeak free right now. G.B.
Old Dec 2, 2008 | 01:21 PM
esmarkey's Avatar
Originally Posted by hyperv6
No suspension noise here but I did have some noise in the console shifter.
I just unsnapped it and put to padding on some of the points it rubbed. Now no noise.
No bed spring noises in my SS in cold (2nd winter it's been through)
Sorry to thread jack, but I do have the shifter console squeaks.... BAD. hyperv6, is yours auto or manual? Any way of taking a pic of the padding you used and how it "unsnapped", so I can do something with mine?
Old Dec 2, 2008 | 01:45 PM
opelpowered's Avatar
brake problems
Has anyone noticed any brake problems in the cold weather. Today my brakes felt spongy. I was even able to push them to the floor when parked. This was acompanied with a pressure release sound. It was almost like the brakes were beeing bled.
Old Dec 2, 2008 | 01:50 PM
esmarkey's Avatar
Oh no, I hope you don't have the dreaded SS brake issue. Does this only happen when 1st started? If so, do a search on cold start SS brake issues.
Old Dec 2, 2008 | 01:51 PM
I dont have an SS. I have the basic LS.
Old Dec 2, 2008 | 01:58 PM
esmarkey's Avatar
Sorry, I assumed you had an SS because this post is in the SS forum...
Old Dec 2, 2008 | 02:49 PM
hyperv6's Avatar
It was simple.
I do have an automatic and the console snaps appart except for two screws at the front behind the storage tray.
All I used for padding is some Butyl rubber. I had a wind shield replacment guy give me a roll of it and it works well for many things.
I just pulled off a small piece of the roll. It is very sticky so I stuck it to where the plastic meets between the two parts. It keep the parts from rubbing against each other.
You could also use a small piece of 3M trim tape. Just don't use a large piece so if it ever needs to come apart you can still get it apart.
As to how it unsnaps pull out the storage tray, take out the two screws and everything pulls straight up from there if I recall correctly.
In a thread here there is a diagram Chevy MGR posted and I used as a guide on where the snaps are.
