Cold weather brings cool noises!
Back from the dealer. In addition to the SS brake fix, the headliner was re-attached neat the sunrrof, which was causing the rattle.
The creaky/squeaky bed-type noise coming from the right front side (started in last 3 weeks, got progressively worse) fixed too with a stabalizer shaft replacement, and also replaced two stabalizer bar bushings and insulators, all under warranty of course.
Hope that helps some when taking their SS's in to the dealer.
Re: Winter noises - check the plastic compartments behind the rear seats!!! Mine had become loose and they mimicked a suspension problem to a Tee!!! Its worse when the cold makes the plastic more rigid. If you can rock the boxes for and aft, they're loose. There are 4 bolts that become visible once you remove the rear cover and spare tire cover. You can also test this theory by releasing a rear seat and then sandwiching a folded towel between the seatback and the boxes and then going for a spin.
CarlsSS
33
Apr 5, 2024 04:17 PM
