Cold weather brings cool noises!
Old Feb 27, 2009 | 06:16 PM
  #51
CGYHHRSS's Avatar
Back from the dealer. In addition to the SS brake fix, the headliner was re-attached neat the sunrrof, which was causing the rattle.
The creaky/squeaky bed-type noise coming from the right front side (started in last 3 weeks, got progressively worse) fixed too with a stabalizer shaft replacement, and also replaced two stabalizer bar bushings and insulators, all under warranty of course.
Hope that helps some when taking their SS's in to the dealer.
Old Mar 3, 2009 | 08:39 PM
  #52
CarlsSS's Avatar
Yup, same here... I just got mine back from the shop tonight and they replaced and lubricated the front stabalizer bushings. All is well now. Nice and quiet so I can focus on that nice exhaust roar and turbo whine!
Old Feb 28, 2011 | 04:47 PM
  #53
Krusty's Avatar
Re: Winter noises - check the plastic compartments behind the rear seats!!! Mine had become loose and they mimicked a suspension problem to a Tee!!! Its worse when the cold makes the plastic more rigid. If you can rock the boxes for and aft, they're loose. There are 4 bolts that become visible once you remove the rear cover and spare tire cover. You can also test this theory by releasing a rear seat and then sandwiching a folded towel between the seatback and the boxes and then going for a spin.
CarlsSS
33
Apr 5, 2024 04:17 PM
Tyler Harvey
Jun 23, 2011 03:21 PM
heritage
Jan 29, 2011 03:13 PM
Big Rad
Dec 28, 2009 10:02 AM
fastsuv
Feb 12, 2008 10:57 AM
