Inspect my brakes please....
Old Jun 8, 2010 | 12:18 PM
1970judge's Avatar
Originally Posted by rdeaniii
I don't care how good or bad your pads are.... I just want the government to force a recall on the HHR and figure out why soooo many people are having warped rotors. I am getting ready to replace mine for a third time. I have 60,000 miles and all Chevy can say is I must not be driving the right way. I guess in their minds you should not use your brakes. The last time I replaced the rotors, I bought a set of upgraded form the OEM set. There is something wrong with the front end design that is causing this. We must all complain to the NTSA and get something done about this. They know they have a problem but will not admit it.
But what about the tons of people who AREN'T having trouble? 63k, I have over 1/2 my pad life still, no warped rotors, and car stops on a dime. Over 50% of the problems could probably be solved by driving habits. They aren'tgoing to recall something that the driver themselves could cause as easily as a defective part can. When the LS7 Z06's first came to, the roofs were peeling off, yeah recall that because the owner has nothing to do with it...but the warped rotor's can be driver fault, OR, malfunctioning equipment.
Old Jun 8, 2010 | 12:50 PM
BlackScreaminMachine's Avatar
my '07 is NON ABS 2.2L Auto with the Traction Control. @ 15k Miles they were warped bad, Dealer first cut the rotor and pad slapped. My must have done it while it was hot or something as when the rotors cooled, ithad a HORRIBLE grinding noise on cold, light break pressure.
After a decent drive or 1 or 2 hard stops it would go away, sound normal, but come back after cooling. Seeming warped so much that when hot, it was fine. Nuts.
So taking it back they replaced rotors and pads and have been fine for the last 6-7k miles.
I also broke in the pads myself, compared to my wife and not a issue since.
Old Jun 8, 2010 | 02:21 PM
mrsilent13's Avatar
just by looking at that picture i would say about 5/32nds of pad left...but it is hard to tell...if you had a tire gauge or something to measure it you would know exactly how much pad is left
Oldblue
Nov 24, 2013 11:18 AM
agrandad
Maintenance and Upkeep
Feb 7, 2012 11:13 PM
mrarff
0
Jan 7, 2011 08:15 AM
savello
Jul 25, 2008 08:27 PM
