New MOOG Control Arm Bushing?
Old 04-10-2018, 08:45 AM
fastsuv's Avatar
It looks like its time to replace a control arm bushing.
I have always used the MOOG problem-solver bushing K6698 ($7.50 at Rock Auto).
Rock Auto now lists another MOOG bushing K201285 as having a "zinc coating for use on aluminum control arms". It's 4x the cost of the K6698. It also appears to be a completely different design.
K6698 Bushing:
K201285 Bushing:
Anyone use the new bushing? Maybe this one would last a lot longer (it better for $28).
Steve
fastsuv is offline
Old 04-10-2018, 09:09 AM
The none zinc coated K200792 version has been installed on Oldblue LCAs since early August 2015.
Old OEM on left, new Problem Solver on right
Oldblue is offline
Old 04-10-2018, 09:26 AM
Technical Moderator
It is a completely different design. The center is a bearing, not just rubber.
donbrew is offline
fastsuv's Avatar
Rock Auto doesn't even list that number under the HHR Suspension parts.
If I do a Manufacturer/Part Number search it does show it for $17.73.
I just ordered the cheap K6698 for $7.50. Maybe I should order the one you used instead. It looks a lot more "substantial".
Steve
fastsuv is offline
Old 04-10-2018, 09:32 AM
A lot more !
And it is listed
https://www.rockauto.com/en/catalog/...m+bushing,7532
Oldblue is offline
Old 04-10-2018, 09:47 AM
fastsuv's Avatar
Originally Posted by Oldblue
That link does not show the K200792.
I do find it using their search.
I cancelled the K6998 order and ordered the one you used (K200792).
Steve
fastsuv is offline
Old 04-10-2018, 09:57 AM
fastsuv's Avatar
According to MOOG's site, K200792 is only listed for the Cobalt (+ other cars) but not the HHR.
They do list the zinc coated one as fitting the HHR. I assume this is because they want you using the zinc coated for aluminum control arms. The zinc one looks just like yours with a zinc coating.
I don't see any problems with using the K200792 that you used except it might corrode faster due to no zinc coating?
Steve
fastsuv is offline
Old 04-10-2018, 10:37 AM
Cat Man HHR's Avatar
Cobalt SS which has the aluminium lower arm is the same for the HHR.
Cat Man HHR is offline
Old 04-10-2018, 11:36 AM
Technical Moderator
Moogs catalog SUCKS when it comes to HHR. They seem to think ALL of the parts are identical to Cobalt base model.
Just because you recognize the name doesn't mean they are better than anybody else. The Moog name has changed hands several times over the years, currently owned by Federal Mogul, automotive suspension parts, at any rate; other types of things owned by other companies.
The Moog inc. company is a Aerospace, Defense, Industrial Automation, and Motion Control manufacturer. Then there is the Moog Music company of synthesizer fame. (E.L.P. fans?)
donbrew is offline
Old 04-10-2018, 05:51 PM
Oh what a lucky man he was!
A few years , couple of winters , no corrosion on the K200792 bushings.
They definitely fit the HHR, the zinc coated ones will work to
Oldblue is offline
Quick Reply: New MOOG Control Arm Bushing?
