KYB shocks and struts for FE5 Suspension
Okay. Thanks for clearing that up. So we have the FE3 suspension and I can probably just use the Monroe QS or an OEM FE3 replacement. I just need to gt them replaced so it drives better.
Your rear shocks are worn out too, if you have more than 50K on them. You will notice the difference, at least in stopping distance.
thanks for the info. I do plan on replacing the rears too. I'm also going to do the sway bar bushings and complete lower control arms. The car is a rattle trap now and after reading the posts I think I'm going to do everything since I'm already tearing it apart. I did the sway bar end links (Moog) about 6 months ago.
purple haze
0
Sep 21, 2008 05:20 PM
